Help with swap
Old Feb 12, 2005 | 07:11 PM
Jasno161's Avatar
Default Help with swap
Well we got my motor dropped in, b16 from Hmotors for my daily driver..
Anyways we hooked up the hoses and power steering etc.
When we went to hook up the wire harness from the engine to the one left on the car(after we pulled out the SOHC) I realized only 1 plug goes together on each side, and the 2 on the passanger side are both female plugs, and so are the plugs coming from the cars harness, so they cant be hooked up.
Im assuming I have to get it wired up at a shop, since I dont know much about the wire part of it all. Do i cut and re-wire or what?? Ill keep searching but I find tons of info that doesnt pertain to me..
Old Feb 12, 2005 | 07:15 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Help with swap (Jasno161)
what car is this motor going into? and what obd motor and car are you working with? we need more info.
Old Feb 12, 2005 | 07:17 PM
KRaZee_TiNy's Avatar
What is the car and is the motor obd2? That will give us some idea and then i be able to help you out.
Old Feb 12, 2005 | 07:18 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
If you aren't 100% confident in your wiring, soldering ability don't **** with it. If your looking at the motor from the front of the car this is what has to be done. The clips that connect the engine harness to the chassis harness have to be switched, IE the ones on the left have to be on the right and the ones on the right have to be on the left. Your motor came from a right hand drive car so that part is backwards. So here's the catch, the clips to all the sensors and **** on the motor have to stay where they are. So you need to extend some wires and shorten others, a big pain in the ***. I'm very capable of doing this and I have been working on the write-up for months now, gotta get it perfect though. Get someone who knows electrical to do it. Pay him/her well.
Old Feb 12, 2005 | 07:20 PM
Default Re: Help with swap (AzntaggeR)
Yeah like thay said too, I was kinda jumping the gun, is it a JDM B16?
Old Feb 12, 2005 | 07:21 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Help with swap (HondaFanatic708)
also, which engine harness are you using? if its the JDM one, it wont work due to it being wired for a RHD.
Old Feb 12, 2005 | 07:28 PM
Jasno161's Avatar
Its a 95 Civic Ex Coupe, and it is a JDM B16, i think im going to have to take it to a shop to finish the wiring, the car is ODB1. Thanks for your fast replies, saves me the trouble of figuring it out.
Old Feb 12, 2005 | 07:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">also, which engine harness are you using? if its the JDM one, it wont work due to it being wired for a RHD.</TD></TR></TABLE> It can work but it has to be fucked with big time, might just be better to buy a harness from a <U>94 DelSol VTEC</U>
Old Feb 12, 2005 | 07:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasno161 &raquo;</TD></TR><TR><TD CLASS="quote">Its a 95 Civic Ex Coupe, and it is a JDM B16, i think im going to have to take it to a shop to finish the wiring, the car is ODB1. Thanks for your fast replies, saves me the trouble of figuring it out.</TD></TR></TABLE> Hey it is our pleasure to help, thanks for being clear and not titling the post "question" most new people on HT are lame as **** but your kewl man, just keep it real and yes take it to a shop.
Old Feb 12, 2005 | 07:37 PM
AzntaggeR's Avatar
TSPeed Factory
just find an obd1 harness and it will plug right up. use your old sohc harness, and the only wire you'll have to add is the knock sensor wire.
Old Feb 12, 2005 | 07:41 PM
Jasno161's Avatar
Where is that available, like a parts store or what?
Old Feb 12, 2005 | 07:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">just find an obd1 harness and it will plug right up. use your old sohc harness, and the only wire you'll have to add is the knock sensor wire.</TD></TR></TABLE> Hey AzntaggeR I can't remember off the top of my head, does the 94 DelSol VTEC have a knock sensor, I'm almost positive it does.
Old Feb 12, 2005 | 07:47 PM
He's saying use the harness from the motor you took out, the only thing you have to wire is the knock sensor, this will be way cheaper if you decide to take it to someone. A parts store will not likely have an engine wireharness, check bone yards if you sold your motor already.
Old Feb 12, 2005 | 07:55 PM
Jasno161's Avatar
So Ill rip out my wire harness and try to get m SOHC engine harness back up in there, because I just did it today so I still have to do the shift linkage and the axles, then the wire harness, and Ill have the knock sensor wired up. Thanks guys
Old Feb 12, 2005 | 08:05 PM
Jasno161's Avatar
Is it fairly easy to remove the harness from all the sensors and stuff, then plug it back in to all the sensors on the B16? I know they cut the battery cables and **** on my b16 so I was gong to have to use the ones from my SOHC reguardless, I guess I should have put 2 and 2 together and realized its meant to use my stock harness.
Old Feb 12, 2005 | 08:16 PM
AzntaggeR's Avatar
TSPeed Factory
yes, just be careful not to break any clips or plugs.
Old Feb 12, 2005 | 08:20 PM
Jasno161's Avatar
Okay, so Ill probably throw a check engine light code because of the knock sensor, but when I get it wired up, and throw in my USDM p30 ecu that im gonna buy, it should be fine?
Old Feb 12, 2005 | 08:24 PM
Yes sir, just make sure to reset the ECU
Old Feb 13, 2005 | 11:39 AM
Jasno161's Avatar
Alright thanks, the motor is already bolted in to al the mounts so im gonna hook it back up to the hoist, and then take the 2 side mounts bolts off to try to let it angle down and remove the harness, then zip tie the sohc harness in..Thanks again everyone
belex202
Acura TL, RL & ZDX
Dec 9, 2009 11:28 AM
meagainsttheworld
Aug 23, 2006 05:31 PM
DRKSol
Jul 17, 2006 11:48 AM
