Help me bypass FITV on AEBS manifold
Old Feb 12, 2005 | 06:37 PM
crexer's Avatar
Default Help me bypass FITV on AEBS manifold
OK, posting here in the crx forum because I hardly ever get much help on the tech forum. So anyway I put the AEBS intake manifold on my b16 last week and it dosent have the spot for the FITV. No big deal because I had the old fitv screwed all the way in on my old manifold so it wasnt doing me any good. My question is how do I go about bypassing this? Do i just run a 3/8" hose from the throttle body to the small nipple on the AEBS manifold next to the larger one; or do I just cap off both? Also my idle is messed up like the IACV is bad but it wasnt doing this before. It just bounces up and down between 1,000-1500 rpms. Should I also try bypassing the IACV as well? Its not throwing any codes for the IACV but it acts like it. help me out here
Old Feb 12, 2005 | 07:53 PM
crexer's Avatar
Default Re: Help me bypass FITV on AEBS manifold (crexer)
bump it up
Old Feb 12, 2005 | 08:10 PM
Reelizmpro's Avatar
Still using the stock 1st gen B16 TB?? Just eliminate the FITV or find a TB with the FITV attached to it. Keep the Idle valve in back of the manifold. I used a couple of inline fittings and coupled the hoses to bypass the FITV but you can use 2 single long pieces of hose. On the back you probably won't use all those vac fittings so cap the extra ones off or run a hose from one to the other. Oh yeah, I used a later style fuel rail with the FPR on the end. I found I had to mount the temp sensor upside down so that I could still use the accelerator cable bracket. I still had to cut a chunk out of the bracket so that it would all fit though. I also used a later LS bored TB with the map sensor on it. Luckily the wiring reached the TB so no extension was needed.
Old Feb 12, 2005 | 10:40 PM
crexer's Avatar
Default Re: Help me bypass FITV on AEBS manifold (Reelizmpro)
saturday night
ek9_klone
Apr 29, 2015 07:57 AM
hectic57
Mar 19, 2008 08:16 AM
zeekekciv
Jun 26, 2006 08:01 AM
pro547
Mar 19, 2005 02:26 PM
comptechgsr2000
May 13, 2002 09:15 PM
