failed emission test PLZ HELP!!!!
ok heres whats going on i got a dx civic with a b20b its manual, has a acura 96-99 ls ecu, i passed everything but i think the ecu part
<U>this is what it says below on the emmisions paper</U>
overall obd result: fail
fault code result: fail
fault codes:p0171,p0141,
ddescription:-
p0141:O2 sensor heater circuit malfunction (bank 11 sensor2)
p0171:system too lean (bank 11)
plz let me know whats wrong what i need to do and how much u think itll cost thanks alot i really apreciate help!
ddescription:-
the bad O2 could do it too. when you replace that clear the code and drive it like 60 miles before retesting so the cars readiness monitors can set.
ok thx alot guy i really aprieciate it
you can leave more replys if yah want to people im still readiing everybody has there own way of doing thing good to see em all thx
Emission test failed : 2001 Honda Civic 2D ,
result
HC ppm : 2 : pass
CO% : 0.14 : pass
NO ppm: 1069 : fail ( almost double )
Dilution : 15.3 : Valid
Note : I had replaced 5 converter last year ( had one year worranty but its just over by 4 month)
I have been advised to change calical converter ( 170$) to pass e-test
please advise what to do
your help will be greatly appriciated
thanks
result
HC ppm : 2 : pass
CO% : 0.14 : pass
thanks
