o2 sensor heater
Old Sep 21, 2008 | 10:43 PM
I has a Teg's Avatar
Default o2 sensor heater
just in advance, i searched and couldn't find anything.. lol
replaced a timing belt recently on my 98 GS and as soon as i fired it up for the first time, it threw a CEL, and i had just reconnected the battery, so the ecu has a fresh reset.
put it into diag mode and gave me a 41 code, being "o2 sensor heater"... i plugged in an obd2 reader and it said "sensor heater circuit malfunction (bank 1, sensor 1)", and code P0135.
is it basically "replace your o2 sensor."? if so, upstream or downstream o2 sensor? and is there any possibility of just cleaning it off like you can an IACV? two completely different things, i know, but gd i'm poor. lol.
current symptoms include, but are not limited to: rough idle(normally on cold start before i drive anywhere, and also when i'm idling after it warms up), HORRENDOUS gas mileage(like 15-20mpg=\ ), significant/noticeable power loss. i also have some weird timing belt sounds that may or may not be relevant, but i'll toss it in for good measure.
i think the timing might be off 180degrees so i'm going to screw w that tomorrow, as well as try to fine-tune the timing to make sure it's on-par.
suggestions? thanks in advance, all.
Old Sep 22, 2008 | 06:40 AM
AWD Terror's Avatar
Default Re: o2 sensor heater (I has a Teg)
I would make sure you put on the timing belt right before you do anything else. Sounds kind of wierd that it was fine before but not the second after.
Old Sep 22, 2008 | 07:51 AM
LSracing94's Avatar
had the same problem, had to replace the primary o2 sensor, "o2 sensor heater" is just one of the 3 or 4 wires that runs off of the o2 sensor that is messed up. get a new o2.
Old Sep 22, 2008 | 08:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Would the car even run if timing was 180 deg. off?
Old Sep 28, 2008 | 05:45 PM
Default Re: (PatrickGSR94)
sorry i haven't been on in a while, been busy as hell lately lol but found out the dizzy won't even go in if it's 180 off. and deducted it has to be the upstream o2 sensor, there's nothing else it could be since tegs don't have egr valves. once i get the money for a new o2 i'll update and let you guys know what's up. thanks for the input
Old Oct 19, 2008 | 03:48 PM
92reddb1's Avatar
anyone that can tell me what wire is the signal sensor wire on an obd 1 integra its a 4 wire sensor and it is not the same colors as the dsm one
randomracing
Dec 26, 2008 08:37 AM
draxxus07
Oct 13, 2005 05:41 PM
JibOnALib
Aug 25, 2005 08:54 PM
cu3tip
Oct 18, 2004 08:26 PM
samvtecaccordsport
Jul 18, 2004 02:13 PM
