Will a fpr help?
Hello all,
Got a jdm b18c with light weight flywheel and crankshaft pulley, stage 1 clutch kit, jdm itr header, 2.5 inch exhuaust, and short ram intake.
With the mods I have installed what would you set the fuel pressure at? I just have the stock fuel rail would it be wise to upgrade to an aftermarket and put the fuel gauge on that? I am planning on putting a b&m fpr on it(purple one).
Thanks
98civic94gsr
Thanks
98civic94gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patmcd »</TD></TR><TR><TD CLASS="quote">You wont need an aftermarket rail. With just those mods an fpr is really needed. </TD></TR></TABLE>
I second that
You'll be fine with the stock fpr.
I second that
with those mods you wont need upgrade fuel yet, honda's and acura's are set to run pretty rich so by adding those things ur leaning the a/f ratio. u can do a couple of things.....ignition system, fuel pump, rest of fuel stuff, cams.
Well I have this soft spot(bog) when I floor it immediately after I shift into a gear. It hesitates for a second or two and then takes off good. I thought maybe I wasn't getting enough fuel. So you guys don't think that is the case? Any ideas what it could be?
Thanks
98civic94gsr
Thanks
98civic94gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civic94gsr »</TD></TR><TR><TD CLASS="quote">Well I have this soft spot(bog) when I floor it immediately after I shift into a gear. It hesitates for a second or two and then takes off good. I thought maybe I wasn't getting enough fuel. So you guys don't think that is the case? Any ideas what it could be?
Thanks
98civic94gsr</TD></TR></TABLE>
sounds like a ignition system problem or the IACV.
Thanks
