no vtec after 2nd motor swap...
Old Feb 11, 2005 | 04:36 PM
ViXoN Hatch94's Avatar
Default no vtec after 2nd motor swap...
changed solenoid and switch, re-wired ground and solenoid, tried different distributor and ecu, checked oil... i used to get code 22 before i re-wired the wires, now i dont get any CEL but still no vtec!!!!!!!! i had a 92b16 in there and everything worked fine... blew the motor and all that was changed was... a new motor, intake manifold & TB, distributor. ive had the wiring checked by 3 mechanics and have been told that my motor is healthy... i read about splicing the vtec solenoid wire to clear up JDM motor complications. im left with no other choices..... anyone????? thanks
Old Feb 11, 2005 | 04:47 PM
Default Re: no vtec after 2nd motor swap... (ViXoN Hatch94)
BTW... i blew the 1st motor by mis-shifting 4th to nuetral and my ecu has a 10k rev limit, now my question is... could my ecu have messed up during the time my motor gave out?
Old Feb 11, 2005 | 09:46 PM
thatbluecrx's Avatar
speedo hooked up??. .. always gotta ask sorry
Old Feb 12, 2005 | 03:23 AM
Default Re: no vtec after 2nd motor swap... (thatbluecrx)
speedo?????
Old Feb 12, 2005 | 08:19 AM
evil civic's Avatar
spedometer....some ecu's you have to be moving at 15mph before vtec will kick in...so if your spedo isn't working you wont get vtec...i stumble round that problem like an idiot for a while bout a year ago...
Old Feb 12, 2005 | 08:46 AM
00000xxx's Avatar
are you running a jdm vtec solenoid with a usdm ecu??
Old Feb 13, 2005 | 04:36 AM
Default Re: no vtec after 2nd motor swap... (ctr610)
ive tried both jdm and usdm solenoids... and ecu is usdm
Old Feb 13, 2005 | 07:01 AM
00000xxx's Avatar
try a different ecu
Old Feb 19, 2005 | 02:14 AM
i get a code 22 cel
D16y8VtecRunner
43
May 11, 2014 09:36 AM
jdm.coupe3234
37
Dec 11, 2009 08:19 AM
2.2accord
Feb 10, 2009 11:23 AM
hondanut
14
Sep 8, 2007 09:25 AM
R-Type R
Jul 28, 2005 08:57 AM
