*ALERT* n00b question about d16y7
Old Feb 11, 2005 | 12:48 PM
v0lcom27's Avatar
Default *ALERT* n00b question about d16y7
What does a d16y7 redline at?
haha, i tryed searching.
Old Feb 11, 2005 | 12:49 PM
WildPig's Avatar
Default Re: *ALERT* n00b question about d16y7 (v0lcom27)
one way to find out for yourself = rev it up and let it bounce off the limiter
Old Feb 11, 2005 | 12:50 PM
Jonzo's Avatar
From: Toronto, Ontario, Canada, North America,, Earth
7100
Old Feb 11, 2005 | 12:53 PM
99hatch's Avatar
Default Re: *ALERT* n00b question about d16y7 (Jonzo)
6800
Old Feb 11, 2005 | 01:05 PM
Mwsol's Avatar
Default Re: *ALERT* n00b question about d16y7 (99hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hatch &raquo;</TD></TR><TR><TD CLASS="quote">6800</TD></TR></TABLE>
Mine seems to go t0 7100. But sence im smart and already know that most honda tachs are off by a few hundred rpm's, I know I'm only going to 6800.
Old Feb 11, 2005 | 01:19 PM
bbarbulo's Avatar
no, fuel cutoff is at 7100 rpm... redline is deemed to be 6800.
and there is no f-in way that a Honda tach is off by a couple hundred rpm... that would so mess up your ignition cuz the signal comes right off the distributor, so if the RPMs were incorrect your car would totally get outta whack on timing. Factory NS guages (Nippon-Seike) are very accurate shockingly enough.
Old Feb 11, 2005 | 02:54 PM
ReDHaTcHyGuy's Avatar
Default Re: (bbarbulo)
7100
Old Feb 11, 2005 | 07:39 PM
v0lcom27's Avatar
Default Re: (ReDHaTcHy97)
ok so is it 6800 or 7200? ive been shifting at 6200 cause thats what edmunds.com says it is...
Old Feb 11, 2005 | 07:47 PM
99hatch's Avatar
Default Re: (v0lcom27)
mine only goes to 6800, but all you gotta do is rev it until it bounces off a certain point
and about the tachs being off...i believe its the needle itself, not the actual number from the sensor.
Old Feb 11, 2005 | 07:57 PM
v0lcom27's Avatar
Default Re: (99hatch)
Ok cool thanks dudes
Old Feb 11, 2005 | 09:09 PM
its 7100 the tach just say's 6800 but the ecu is set at 7100
Old Feb 11, 2005 | 09:25 PM
^CX_d16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo &raquo;</TD></TR><TR><TD CLASS="quote">no, fuel cutoff is at 7100 rpm... redline is deemed to be 6800.
and there is no f-in way that a Honda tach is off by a couple hundred rpm... that would so mess up your ignition cuz the signal comes right off the distributor, so if the RPMs were incorrect your car would totally get outta whack on timing. Factory NS guages (Nippon-Seike) are very accurate shockingly enough. </TD></TR></TABLE>
he's right fuel cut-off is at 7100..
the REDLINE is at 6800
Old Feb 11, 2005 | 11:05 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (^CX_d16)
Redline IS 6,800 RPM. Verified by MY D16Y7 and a Helms manual.
Fuel cutoff is 7100RPM based on my persona experience.
accord03coupe
Honda S2000
17
Mar 27, 2007 03:28 PM
asianspec
15
Jan 28, 2005 09:58 AM
bseries_beast
Dec 30, 2004 02:15 PM
DOHClessEF-9
Nov 21, 2004 06:45 PM
Behan
May 16, 2003 09:18 AM
