b16 ecu help 3 beep 4 beep 5 beep
Old Feb 11, 2005 | 06:44 AM
hotimportcrx's Avatar
Default b16 ecu help 3 beep 4 beep 5 beep
my jdm b16 in my 89 crx with the regular ecu ....the check engine light is on and the led beeps 3 times stops then 4 times stops then 5 times stops then goes back to 3 times stops 4 times stops...etc....can anyone please help
Old Feb 11, 2005 | 06:48 AM
EP3_05's Avatar
Default Re: b16 ecu help 3 beep 4 beep 5 beep (HondaDelsol17)
Yes they are codes 3 4 and 5
3-> MAP sensor electrical problem
4-> Crank Position Sensor
5-> MAP sensor - mechanical problem
Did this just all of the sudden pop up or did it happen right after you swapped the engine? Also try to obtain a factory service manual for your car which will have ways of troubleshooting these error codes.
Old Feb 11, 2005 | 06:53 AM
Default Re: b16 ecu help 3 beep 4 beep 5 beep (91civic)
the check engine light has been on just the first time i checked it...
eg2tr
Jan 5, 2008 09:36 PM
itsjdmbradyo!
Sep 19, 2006 10:25 AM
crxmadness
Jan 20, 2006 10:19 AM
turbosi03
Jan 21, 2004 08:04 PM
