tranny help
i have an auto 95 integra i wanna do a manual tranny. i have the tranny ecu pedels everything but the lines how hard is it to swap the trannys. is it worth me doing my self or should i bring it to a tranny shop??? does any body have a guide on how to do it.
i pulled this from another thread on here:
1. The trans.
2. Linkage rod assembly (any 94-01 teg)
3. Manual trans. console
4. Shifter and ****
5. Manual ECU
6. Pedal assembly (94-01 civic or teg)
7. Clutch slave and master cylinders
8. Clutch fluid container
9. Clutch hard lines and hoses
10. Flywheel and bolts
11. Clutch set with alignment tool and throw out bearing.
12. Manual intermediate shaft (94-01 teg, 95-97 delsol, 99-01 civic)
13. Rear trans. mount bracket for manual trans. (94-01 teg only!)
14. Front trans. mount bracket for manual trans.
15. After re welding the bracket on chassis, a top tran. mount for manual trans. (94-01 teg)
16. Starter for manual trans.
17. Lots of spare bolts and nuts
18. Air tools
19. GM syncromesh #12345349, 3 quarts.
1. The trans.
4. Shifter and ****
5. Manual ECU
18. Air tools
AznInvasion
Sep 12, 2003 06:19 PM
