will this ITR part work on a LS motor
Old Feb 10, 2005 | 12:41 AM
slammed_93_hatch's Avatar
Default will this ITR part work on a LS motor
i *THINK* its called a gridle, but im not sure. it came off of my ITR motor, and im selling it, will it fit, a b18b, and other b series motors.
Thanks
Old Feb 10, 2005 | 01:07 AM
SlowReaction's Avatar
Default Re: will this ITR part work on a LS motor (slammed_93_hatch)
It can but with some work. The ls caps have to be machine to the correct height so that the girdle sits flush. Then the Mains need to be drilled for the dowels to fit. After you do that it is recommended that you get a line hone so that the mains are straight which is around 100 i think. Hope that helps. Some guy actually did a right up on this so try a search also.
Old Feb 10, 2005 | 12:32 PM
gsrswapdcivic's Avatar
damn dude that metal doesnt look to good. is that the reason your selling
Old Feb 10, 2005 | 02:55 PM
Default Re: (gsrswapdcivic)
https://honda-tech.com/zerothread?id=1041459
hmmm thats the hole story
Old Feb 11, 2005 | 04:34 AM
vbphreak's Avatar
Default Re: (slammed_93_hatch)
The person buying that girdle will also need the windage tray, oil pick up and the oil pan.
Old Feb 11, 2005 | 01:07 PM
Default Re: (vbphreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vbphreak &raquo;</TD></TR><TR><TD CLASS="quote">The person buying that girdle will also need the windage tray, oil pick up and the oil pan.</TD></TR></TABLE>
all three of those are destryod
boostincoupe
Feb 29, 2008 03:52 PM
civicsaremean
Jul 20, 2007 05:33 AM
EDVxRICHARD
12
Jul 3, 2005 04:48 PM
Nextelbuddy
Feb 10, 2004 09:31 PM
Black R
Oct 22, 2003 11:47 AM
