Will a GSR oil pan fit a LS block?
Old 02-27-2008, 04:54 PM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Will a GSR oil pan fit a LS block?
I'm sorry to be asking this question here, but I'm sure a lot of you LS/VTEC guys have dealt with this before.
I'm simply wondering if my tapped ITR oil pan will fit on a B18A1 block. I cracked a sleeve in my ITR block, so it's going on the shelf until winter so I'm running a LS/VTEC for this season.
Also, will I have to swap over my oil pickup tube, or is the LS pickup tube sufficient?
Anything else I need to swap over? Thanks!
Old 02-27-2008, 05:17 PM
CoreyR's Avatar
Default Re: Will a GSR oil pan fit a LS block? (boostincoupe)
you need the pickup as well. i assume youll be using the ITR oil pump on the LS as well and not the LS pump (i hope)
Old 02-27-2008, 05:25 PM
Default Re: Will a GSR oil pan fit a LS block? (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">you need the pickup as well. i assume youll be using the ITR oil pump on the LS as well and not the LS pump (i hope)</TD></TR></TABLE>
Yes of course.
OEM ITR oil pump, water pump, timing belt and tensioner
Old 02-29-2008, 10:36 AM
Can anyone confirm that I ONLY need to replace the oil pickup? What about the ITR windage tray?
Old 02-29-2008, 03:52 PM
ctr83's Avatar
yes you have to use the pickup and windage tray
DC2fab
01-16-2010 01:37 PM
MasterLsGod
10-24-2009 05:02 PM
b20quang
04-23-2008 11:06 PM
kikwear002
01-26-2005 08:08 AM
Quick Reply: Will a GSR oil pan fit a LS block?
