Need Help W/Oil Leak
I recently noticed this leak and it worries me, just began maybe a month ago. I want to know it is serious, how much it might be to fix it or if i can fix it myself. Any help in this matter is appreciated. TIA
Modified by Dres at 1:36 PM 2/9/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperX »</TD></TR><TR><TD CLASS="quote">the pic is right....looks like number 12. if i remember correctly, it should come with a small screen</TD></TR></TABLE>
Can anyone confirm so I can order online?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dres »</TD></TR><TR><TD CLASS="quote">
Try to order em at http://www.acuraparts247.com and try to ask em and confirm it if its the right part number..
</TD></TR></TABLE>Try to order em at http://www.acuraparts247.com and try to ask em and confirm it if its the right part number..
OMG, I can't believe so many people read this thread and is going to let this poor soul order the wrong part
It's #8 in the picture, not #12!!!! It's commonly refer to as a cam seal as many but the correct name is cam end plug. It's a very common problem with the plug going bad on b-series motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dres »</TD></TR><TR><TD CLASS="quote">thank you all for the help, I figured after a few posts that it was the cam seal.
while your at it, get the solenoid seal too, it wouldn't hurt ....
also pic up some hondabond
</TD></TR></TABLE>while your at it, get the solenoid seal too, it wouldn't hurt ....
so far I understand I should get a new cam seal (aftermarket) , vtec solenoid gasket (part #10 and #12)
and a new head cover gasket (part #7)
any thing else I should order while I'm at it?
ooh and some hondabond ( can i just use gasket tube from auto store?) sorry for asking such detail just wanna make sure i get it right.
you got it man.. any kind of gasket sealer works.. just be careful when tighten back the valve cover & cam seal cover bolts.. 7.2 ft.lbs. i believe. they will break so easily!
yeah thanks, I read your thread and noticed you broke your bolts. as for the tq. specs I am just going to follow the TI article on replacing the cam seal. maybe I ll order an extra pair of bolts just in case
r90crxhf
11
Aug 9, 2011 05:10 AM
spooncivic1
46
Sep 1, 2004 11:14 AM
_Endless_
Mar 20, 2004 07:36 AM
