CEL codes after B18B swap! HELP!
After swapping in the engine i'm getting a code 14 (iacv) and 3 (map sensor)...Anyone ever had these problems? The B18B is a obd1 which i swapped it over to my EG...Any help would be appreciated...Thanks
check the wiring connections to make sure they are plugged in. If you are using the same harness you had before and getting these codes, check the sensors.
I'm using the harness that came with the motor...it's uncut and in good shape...would i have to repin the ecu or anything(sorry first time swapping a motor)?
tomu06
Jul 9, 2012 01:18 PM
tlieu88
Dec 27, 2001 08:51 AM
