zex nitrous
Old Jan 16, 2002 | 09:59 AM
BEEFEDUPACCORD's Avatar
Default zex nitrous
what do you all think of a zex kit on a 2002 accord sohc?
Old Jan 16, 2002 | 10:03 AM
Spade's Avatar
Default Re: zex nitrous (BEEFEDUPACCORD)
Upgrade fuel system and don't go over 55 on the shot!!!!
Old Jan 16, 2002 | 11:53 AM
Default Re: zex nitrous (Spade)
what do you mean upgrade fuel system?
Old Jan 16, 2002 | 12:15 PM
Spade's Avatar
Higher flowing fuel pump.
Fuel pressure regulator.
Nitrous is just a way to add more air into the mix.....add more air = the need for more fuel. If you don't have the correct amount of fuel you start damaging your goods.
I say 55 shot no more because you don't want to cook your rings or risk throwing a rod. If you feel you want to go higher look into building the bottom end. Oh and when driving on the street disconnect the hose from the bottle or you get ticketed.
Old Jan 16, 2002 | 01:46 PM
delacampos's Avatar
it'll pull. IMO, I think a NX kit would better suit you though. If not a NX kit, just go with a wet kit. dry kits suck.
Old Jan 16, 2002 | 02:13 PM
Turboholic's Avatar
Default Re: zex nitrous (delacampos)
The Zex kit is cool. But just a recomendation. Run one size larger on the FUEL jet that what the directions tell you. I have had someone kill thier motor on what jets they say to run. The last 2 that I have installed on some friends cars I ran the one size up fuel jet and never had any problems to date.
N1 Andy
Aug 31, 2007 04:51 AM
djtony5
Feb 24, 2006 01:03 PM
DOHC VTEC EG
Feb 5, 2004 05:33 PM
Clean91B18A1
Jan 25, 2003 08:43 AM
v-tec crx
13
Dec 26, 2001 06:19 AM
