starter crank noise
Old Feb 7, 2005 | 06:42 AM
alfee's Avatar
Default starter crank noise
ok i just had this problem yesterday. i turned the egnition on and i hear this loud crank/scratch noise coming from the starter/engine. sounds exactly like if i already started the car and was still cranking the key to start. what could be the problem? is my starter burnt or messed up? the only reason i can think of what may of happened is that while i was driving on the freeway, my car threw a check engine light because it was running too rich, so i had to pull off on the freeway and turn off and back on my car to kill the check light. hrmmm. please help!
Old Feb 17, 2005 | 06:38 PM
precord96's Avatar
Default Re: starter crank noise (alfee)
Find out what it was? I have the same problem, but I was thinking that it was the ICM/igniter
Old Feb 18, 2005 | 06:07 AM
JimBlake's Avatar
Default Re: starter crank noise (precord96)
Maybe a tooth busted off the flywheel? Or the starter pinion gear is chewed up?
Old Feb 18, 2005 | 10:54 AM
thatbluecrx's Avatar
Default Re: starter crank noise (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Maybe a tooth busted off the flywheel? Or the starter pinion gear is chewed up?
i think that have that... crank crank crank SHINKKKK vroooooom ....... lol
udechukwu
Oct 2, 2009 10:03 AM
speedracer33
11
Jul 11, 2005 08:00 AM
kmf0211
Jul 3, 2005 03:39 PM
NinjaTech
May 20, 2005 08:12 PM
hodsintegra23
Mar 5, 2004 01:40 AM
