Car Breaking Up At Higher RPM's
Old Feb 6, 2005 | 06:52 PM
Beezle's Avatar
Default Car Breaking Up At Higher RPM's
We'll I've been having this problem the past month, maybe longer. When I bring the rpm's up in car it will break up. It sounds like it's hitting the rev limiter but it's not. I'll be pulling then all of a sudden it just kind of come to a stop and then it will go again (sorry trying to make sense, it's hard to explain). At first it was doing it right before I redlined. Someone said my fuel injectors might be dirty so I bought some high milage fuel injector cleaner at Aid Auto. Put it in, was running a lot better and it wasn't breaking up nearly as much. 2 days later it's running like crap again and now it's breaking up at a lower rpm (around 5k-6.5k). By the way the car is a 97 GSR with 110k miles. Any ideas on what it could be?
Old Feb 6, 2005 | 07:35 PM
fastrunner's Avatar
Default Re: Car Breaking Up At Higher RPM's (Beezle)
the switch from non vtec lobes and fuel table to vtec lobes and fuel table
Old Feb 6, 2005 | 11:42 PM
mustbenu's Avatar
Default Re: Car Breaking Up At Higher RPM's (fastrunner)
make sure you have enough oil in your car... that will make you come in and out of vtec
Old Feb 9, 2005 | 09:19 AM
Beezle's Avatar
Default Re: Car Breaking Up At Higher RPM's (mustbenu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustbenu &raquo;</TD></TR><TR><TD CLASS="quote">make sure you have enough oil in your car... that will make you come in and out of vtec</TD></TR></TABLE>
Just checked the oil. It has enough. Any other ideas? This is really bothering me.
Old Feb 9, 2005 | 10:34 AM
Dropped90Integra's Avatar
If the fuel injector cleaner was working than my thoughts are they are dirty again. That can happen because you might have rust at the bottom of your fuel tank, when you run it low on gas its suckin up all that rust crap and your fuel filter can't stop it all. To dignose this, change your fuel filter and dump the gas out, see if its clear like it should be, if not and its orange color, you got rust. Just a thought, happen to me before. Good Luck
Old Feb 9, 2005 | 11:10 AM
TegBen's Avatar
I was having a similiar problem if not the same with my ls. Assuming the problem isn't related to vtec, i can tell you that my problem was timing. Check your timing belt and make sure the car is in time. Other than that, a good ole tune up will do wonders. New plugs, wires, dizzy cap and rotor button fixed my problem. But the key problem was timing. I'm sure that will fix your problem.
Old Feb 9, 2005 | 03:19 PM
Beezle's Avatar
Default Re: (BlackRS)
Holy crap scratch what I said before. My oil is lower than the first dot on the dipsick! Plus I have a oil leak that looks like it's coming from the head. It goes down to wear the engine code on the block is stamped in. I'll have to change the oil tomorrow and see if I can get some new gaskets.
Old Feb 9, 2005 | 06:37 PM
mustbenu's Avatar
Default Re: (Beezle)
i never trust my dipstick
Old Feb 10, 2005 | 07:13 PM
Beezle's Avatar
Default Re: (mustbenu)
We'll I just changed my oil. Went for a test drive. The first 2 pulls were nice, it wasn't breaking up at all. After that, it just went back to normal. Anyone have any more ideas? This is really annoying me.
Old Feb 10, 2005 | 07:47 PM
boosted k20's Avatar
u said ur leaking oil by the head.... maybe a blown headgasket. take ur plugs out and see what condition they're in.
if the headgaskets good then my guess would be timing or fuel
Old Feb 10, 2005 | 07:51 PM
Beezle's Avatar
Default Re: (boosted k20)
I'll check first thing tomorrow. Will get back to you guys. Thanks.
Old Feb 11, 2005 | 09:25 AM
Beezle's Avatar
Just checked my sparkplugs. The on all the way on the right if filled with oil! How would that happen? I'm trying to clean it off right now, any ideas on best way to clean it? I'm using paper towels right now. Gonna take pictures and upload them any minute.
Old Feb 11, 2005 | 09:33 AM
Beezle's Avatar
Sorry for the crappy pics, my camera sucks.
Here's my oil leak.
All 3 of the other spark plugs are dry. Any ideas?
Old Feb 11, 2005 | 09:42 AM
BigC-ivic's Avatar
valve cover gasket could be gone...
Old Feb 11, 2005 | 10:03 AM
Beezle's Avatar
Default Re: (BigC-ivic)
Oh yeah and here are my plugs. They are black at the bottom.
Changed them not to long ago. They're shot right? Also the sparkplug wires got some oil on them, should I just dry em off and they'll be reuseable or no, I should buy new ones?
Old Feb 11, 2005 | 10:19 AM
LSvtec03's Avatar
Default Re: Car Breaking Up At Higher RPM's (Dropped90Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropped90Integra &raquo;</TD></TR><TR><TD CLASS="quote">If the fuel injector cleaner was working than my thoughts are they are dirty again. That can happen because you might have rust at the bottom of your fuel tank, when you run it low on gas its suckin up all that rust crap and your fuel filter can't stop it all. </TD></TR></TABLE>
hmm. probably not, because the gas would keep the inside of the tank from rusting, but it still may be a possibility.
also looks like your valve cover grommets need replacing, so it could be that you're getting oil on the tops of the plugs and getting shitty spark. i've seen that happen many a-time. change those out. and that oil leak on the side under the vtec solenoid could be your cam endcap leaking. also a common problem, and a fairly easy fix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustbenu &raquo;</TD></TR><TR><TD CLASS="quote">i never trust my dipstick</TD></TR></TABLE>
why not? that's what it's for. how else do you check your oil level?
edit: w00t, 1023. you chemistry people know what im talkin about.
Old Feb 11, 2005 | 06:17 PM
Default Re: Car Breaking Up At Higher RPM's (LSvtec03)
definitley replace those spark plugs. and if there's oil inside the cylinder as well as outside on the block, then my guess is that ur headgasket's blown
turboH22Aakkord
Oct 8, 2005 05:15 AM
99BlackSH
May 3, 2004 01:29 PM
Witty
May 28, 2003 06:10 AM
NoLipRacen
Jan 24, 2003 11:12 AM
