Turbo B18C Setup Question
Old Feb 5, 2005 | 03:37 PM
JL1120's Avatar
Default Turbo B18C Setup Question
Hey guys I'm new to the forum and have a couple questions on a future setup that hopefully I can get answered....
I plan on dropping in a B18C, http://www.hmotorsonline.com/s...30008, into a 96 integra and then turboing it. However I want to run around 12 psi on a daily basis and occasionally raise it for racing or when I go to the track. I know that if I want to run at that psi I'll need to upgrade some of the internals, pistons, rods, rings. My question is what is a safe compression ratio for that setup? Also, are there any other upgrades I'll need to make to the engine besides those?
I did use the search, but couldn't find anything to answer my question. Thanks in advance.
Old Feb 5, 2005 | 07:56 PM
PrettyLude's Avatar
what are your power goals?
Old Feb 5, 2005 | 08:09 PM
JL1120's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">what are your power goals?</TD></TR></TABLE>
Around 300 whp
Old Feb 6, 2005 | 09:05 AM
JL1120's Avatar
Default Re: (JL1120)
Lunch bump
Old Feb 6, 2005 | 09:19 AM
PrettyLude's Avatar
for 300 whp i would just leave it at 10 to 1, people on this board are making that on stock block and internals
Old Feb 6, 2005 | 11:35 AM
JL1120's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">for 300 whp i would just leave it at 10 to 1, people on this board are making that on stock block and internals</TD></TR></TABLE>
Thanks for the info Lude. Lets say down the line I want to make more, should I take the compression down to 9:1? Running at 9:1 would be good for how much hp and torque?
Old Feb 6, 2005 | 06:54 PM
primeredbeast's Avatar
9:1 is a great pump gas compression for anything up to 350 or even higher
Old Feb 7, 2005 | 06:41 AM
PrettyLude's Avatar
Default Re: (primeredbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredbeast &raquo;</TD></TR><TR><TD CLASS="quote">9:1 is a great pump gas compression for anything up to 350 or even higher </TD></TR></TABLE>
Old Feb 7, 2005 | 08:30 AM
JL1120's Avatar
Yeah I would be running on pump gas. Maybe I should go ahead and just upgrade the internals while the engine is already out of the car. Do you have any suggestions on parts? Here is what I was thinking...
JE Pistons - Skunk2 cams - AEM cam gears - Eagle Rods....Anything else?
Old Feb 8, 2005 | 08:18 AM
JL1120's Avatar
Opinions?
schmitty-1
Sep 17, 2010 07:58 AM
Chiggah
Oct 7, 2005 05:57 PM
ruckussss
Sep 14, 2005 04:20 AM
BrianDelSol
Jan 23, 2005 07:23 PM
Sh4rky
May 1, 2004 02:31 AM
