Studdering and staling y7
Old Feb 5, 2005 | 02:59 PM
TurboTagTeam's Avatar
Default Studdering and staling y7
Today I installed the apexi v-afc on my y7. Im using it because i plan on buying bigger injectors for my upcomming turbo project. After everything was installed i started it up and threw 2 codes. Code 3-Absolute manifold pressure and code 17- vss sensor. The car feels like it would if you gave it to much clutch. It sputters and wants to stall. If you give it a little gas and power through it, it will go. The v-afc is set to factory specs. Any ideas what could be causing this?
Modified by TurboTagTeam at 8:47 PM 2/5/2005
Old Feb 5, 2005 | 03:38 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Studdering and staling y7 (TurboTagTeam)
Check the wiring.
Old Feb 5, 2005 | 03:45 PM
the only pin out I could find was one for a y8. So i went by that exept the vtec wires.
Old Feb 5, 2005 | 07:46 PM
ttt-help me out!
95accordh22a
Nov 21, 2004 08:57 PM
97dc2
Sep 19, 2004 08:54 PM
topsekret
Dec 22, 2002 05:49 PM
AfEn808
Jan 27, 2002 03:01 AM
VTECHGSR
Dec 12, 2001 08:55 AM
