shavings on my oil pickup screen...
Old Feb 3, 2005 | 09:15 PM
MugenFlaredCRX's Avatar
Default shavings on my oil pickup screen...
So my problem arose when my car started to lose power from above 2500rpms, and it would just kinda cut out and have 0 power like i wasn't even pushing the gas down. and my oil light would flicker to the idle speed and whatnot. so i decided to pull my oil pan and check if my oil pickup line to see if it was clogged. i was pretty pissed off to see , not shavings, but it looks like flakes of metal in the pickup screen. i'm pretty pissed off right about now b/c i'm sure its flakes of my cylinder walls so if anyone has had this problem. gimme some info.
josh
Old Feb 3, 2005 | 09:19 PM
turboZChatch's Avatar
Default Re: shavings on my oil pickup screen... (MugenFlaredCRX)
before you say it is your cylinder walls pull off the rod caps and see what the bearings look like it sounds like your bearings are done......this happend to me and the bearings were destroied along with the crank and the rods
cbrodac0424's Avatar
sounds like u might of spun a rod bearing
Old Feb 3, 2005 | 09:20 PM
Jonathan_ED3's Avatar
how is your oil level?
More importantly, how has it been the past mileage?
B18CivicHatch
Sep 28, 2007 08:38 PM
HatchEh2
Aug 25, 2005 04:35 PM
b18cvtec
Feb 11, 2005 10:07 AM
MugenFlaredCRX
Feb 4, 2005 08:11 AM
dwilson
Aug 6, 2002 05:49 PM
