Ls-vtec build question...remove oil orifice on top of block???
Do you have too remove this on top of the block?I believe you have too for a mini-e.I was just wondering if you have too do this for ls vtec swap
if your using a golden eagle conversion kit, or even simply running your own stainless lines from the oil pressure sender unit, NO, do not remove that orifice, you do need to plug one of the holes underneath the head though.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPATIENT »</TD></TR><TR><TD CLASS="quote">if your using a golden eagle conversion kit, or even simply running your own stainless lines from the oil pressure sender unit, NO, do not remove that orifice, you do need to plug one of the holes underneath the head though.....</TD></TR></TABLE>
yes i am running that kit.Also a few other kids in my class are building a jdm b18c and i noticed the oil seperator.As well as all these other things on the back side of the block.Are these essential items for having a good working ls-vtec?
fake mugen power
Apr 22, 2005 08:41 AM
