need help on replacing glass in passenger window
its a 93 civic dx 4 door, power windows
i need to know the basics and any other technical problems i may encounter
anyone have any experience?
I SEARCHED FOUND NOTHING
Modified by DOHC_VTEC69 at 11:42 PM 2/2/2005
put the window down about 3/4 way and then take the door panel off and then inside the door you can see the window inside the plastic and there are 2 bolts that hold the window to the track and loosen them and slide the window back and then you can pull it up and out
1) Take off door panel. 1 screw under mirror, 1 screw in little handle tray, 1 screw behind door handle. Disconnect all switches that connect to power door locks/ windows etc
2)Roll the window down almost to the bottom. Look in the hole of the door frame and you'll see the glass. There are two bolts that attach the glass to the regulator arm. Undo those two bolts, then slide the glass out from the top. Replace with new glass.
Good to go.
Good to go.
VTECwalka
Apr 25, 2013 06:26 AM
Tomas P
Apr 6, 2012 12:06 AM
BULL3TPR00F
Aug 15, 2008 08:28 PM
