rattleing cat...how do i make it stop?
Old Jan 15, 2002 | 09:47 AM
xXreaperXx's Avatar
Default rattleing cat...how do i make it stop?
my cat wont stop rattling...i need ot make it stop...any suggestions (perferably tings i can do in my drive way
Old Jan 15, 2002 | 09:52 AM
Spade's Avatar
Default Re: rattleing cat...how do i make it stop? (xXreaperXx)
Wrap the bitch in exhaust wrap........20 bux from summitracing.com
Old Jan 15, 2002 | 09:56 AM
DIZASTICAL's Avatar
punch it out . it sounds like the honey combs inside are broken .
Old Jan 15, 2002 | 10:20 AM
markedOO1's Avatar
Default Re: rattleing cat...how do i make it stop? (DIZASTICAL)
take the heat shield off and look to see if there's any rocks stuck up there. that's pretty common
Old Jan 15, 2002 | 10:25 AM
dirtySOHC's's Avatar
my does the same thing....but it only started when i gutted it out......oops....
Old Jan 15, 2002 | 12:27 PM
xXreaperXx's Avatar
Default Re: rattleing cat...how do i make it stop? (Spade)
hey i got an hx too...98.....what do u have done to urs..im planing on doing ome mods soon? what brands did u go with for intake, and exsaust...if u got them?
Old Jan 15, 2002 | 12:50 PM
nwdave's Avatar
My heatshield had rusted part way off and that was what was rattling on my cat. Get under the car and check it out.
Old Jan 15, 2002 | 12:57 PM
iceburgslim's Avatar
Default Re: rattleing cat...how do i make it stop? (delsolguy)
There is a 99% chance that the mounting holes on the cat have just rusted out, so it's rattling. Get a pair of vise grips and rip it out, you dont need it anyway. This is extremely common. I hope this helps. Later!
Old Jan 15, 2002 | 01:00 PM
Spade's Avatar
I have a DAC intake.
DC Sports 4-2-1 ceramic header (whatever.....)
Unknown cat-back pulled it from my EX.
If you really want to keep the HX, get an EX intake manifold (Type R of the D series). Get yourself a EX transmission (stronger and higher gearing). DON"T get an EX head. The cam specs are better on the HX. I am looking into re-sleeving the block to 79mm. Custom pistons and rods. And then after that port and polish the head and other things.
Susepension: Neuspeed Sport springs, stock shocks, APC rear strut bar (hey it was 40 bux). Wiating to go in. SI front sway, Type R rear sway.
Old Jan 15, 2002 | 05:46 PM
deepnite's Avatar
think ur cat. has seen its last days..get another or get bust d
Old Jan 15, 2002 | 06:19 PM
Phil B's Avatar
Default Re: rattleing cat...how do i make it stop? (deepnite)
I've had rattling cats on both my Civics. In my experience it's usually just the heat shield. the mounting holes rust out and it vibrates. Always finds it's favorite frequency at about idle to really embarass you at stoplights.
just remove the heat-shield. Keep the cat and don't gut it. they're there for a reason.
Old Jan 15, 2002 | 06:48 PM
johnny hatchback's Avatar
Default Re: rattleing cat...how do i make it stop? (Barabus)
if its not the heatshield then its the honeycomb, if it is then buy a new one
Old Jan 15, 2002 | 07:45 PM
JSTOCK's Avatar
That surely got me rollin' in laughter!!!! Been there, done that!!! LOL!!!
Old Jan 15, 2002 | 08:10 PM
spyder's Avatar
New User
Default Re: rattleing cat...how do i make it stop? (jstock107)
The same thing happened to me, it was so bad I drove our Suburban until I had time to fix it just because I didn't want anyone to think I wasn't taking care of my honda.
Old Jan 15, 2002 | 08:34 PM
EVIL Lovebuzz's Avatar
New User
Default Re: rattleing cat...how do i make it stop? (spyder)
Are you sure it's not your heat shield? I thought it was my cat making that annoying sound, but it just turned out to be the heat shield.
JDMEK9R
Jan 9, 2008 10:58 AM
IntegraLs94Cam
Oct 1, 2004 05:43 AM
Token Blk Guy
Sep 14, 2002 10:46 AM
dirtySOHC's
Feb 1, 2002 10:48 PM
xXreaperXx
Jan 16, 2002 12:46 PM
