IS TOO MUCH OIL IN A HONDA BAD???
Old Feb 2, 2005 | 10:11 AM
superhatchbackbros's Avatar
Default IS TOO MUCH OIL IN A HONDA BAD???
I HAVE A 1989 HONDA CIVIC HATCH.... AND I CHECKED THE DIP STICK AND IT SAID IM UP OVER THE TOP CHECKPOINT.. AND A LIL HIGHER THEN IT.... IS THAT GOOD OR BAD?? MY MOTOR IS SMOKIN A LIL MORE..... AND IT FEELS A LIL SLUGISH... DOES THAT HAVE TO DO WITH TOO MUCH OIL?>??? OR SHOULD I JUST LEAVE IT GO AND BURN IT OUT?? PLEASE LET ME KNOW ASAP THANKS...
Old Feb 2, 2005 | 10:14 AM
hatchinprogress's Avatar
Default Re: IS TOO MUCH OIL IN A HONDA BAD??? (superhatchbackbros)
yes too much can be to bad i think thats why you are smoken and from what i have been told too much oil is bad on the seals
Old Feb 2, 2005 | 10:16 AM
Kyoji's Avatar
If you have too much oil in the pan, the crank will whip it into a foam. Now, your engine bearings and such are being lubricated and cooled by half oil, half air. Air does not cool and does not lubricate. Bad bad bad.
I don't know how much you have overfilled, but it wouldn't hurt to drain a bit.
Old Feb 2, 2005 | 10:20 AM
EP3_05's Avatar
Change the oil and filter and refill with 4 qts. Simple as that. And yes you car will smoke if you have too much oil in the pan.
Old Feb 2, 2005 | 10:25 AM
CRseXy's Avatar
Default Re: IS TOO MUCH OIL IN A HONDA BAD??? (91civic)
Depends on HOW much oil you got in there. If you put in 5qt's thats diffrent. If you put in 4.2 That ant ****. our old *** cars arnt that Finicky.
Old Feb 2, 2005 | 10:29 AM
rioninja's Avatar
Yeah, just a little over the top mark isnt gonna hurt anything. An extra quart is another story though..
Old Feb 2, 2005 | 11:06 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">Change the oil and filter and refill with 4 qts. Simple as that. And yes you car will smoke if you have too much oil in the pan.</TD></TR></TABLE>
thats overfilling right there...
Old Feb 2, 2005 | 11:11 AM
manson's Avatar
Default Re: IS TOO MUCH OIL IN A HONDA BAD??? (crxgator)
no need to change the oil unless its time for it. just drain some and be done with it.
BTW how much over is it?
my dip stick shows about 1/8th inch over the fill line after an oil change.
h22lude317
Jan 9, 2009 08:39 PM
david90
Jun 8, 2004 10:46 AM
KCLude01
Oct 13, 2003 01:27 PM
intekragsr
Sep 25, 2002 03:35 PM
jond
Jan 30, 2002 01:17 PM
