Bad to have a too much oil???
Old Sep 25, 2002 | 11:44 AM
intekragsr's Avatar
Default Bad to have a too much oil???
I have a simple quick question:
Is it bad to have a little too much oil in the motor? The line is about 2.5 centimeters over the second dot on the dip stick. Is this bad?
Thanks for your time.
Old Sep 25, 2002 | 11:56 AM
Trigun's Avatar
Default Re: Bad to have a too much oil??? (intekragsr)
2.5cm sounds like you poured in a quart too many. drain some oil ASAP.
Old Sep 25, 2002 | 12:03 PM
intekragsr's Avatar
Default Re: Bad to have a too much oil??? (Trigun)
thanks edwin. Can this make loss of power btw?
Old Sep 25, 2002 | 12:48 PM
shadowdawn's Avatar
Definatly WAY too much oil you should be AT the second dot even 1-3mm below is ok...... I made the mistake of putting too much oil and my turbo started eating oil because the already weakened seals were pooping out oil.... drained oil back to 2nd dot on the nose and now its not eating anywhere near as much oil, at least not enough to give me white/blue smoke of anykind at any rpm.....
Old Sep 25, 2002 | 01:16 PM
mos's Avatar
mos
I've heard it can cause the oil to foam up. The foamed bubbly oil does not protect as well. Probably worth it to get under there and drain some out.
Old Sep 25, 2002 | 01:27 PM
madman604's Avatar
Default Re: Bad to have a too much oil??? (mos)
too much oil will cause a James Bond type smoke screen
Old Sep 25, 2002 | 01:30 PM
intekragsr's Avatar
Default Re: Bad to have a too much oil??? (Turbo E)
hehe ok guys. THanks. I just drained it./
Old Sep 25, 2002 | 03:35 PM
DC2_Integra's Avatar
so how many quarts do u guys put in a GSR?
EG_Civic_Si
Feb 6, 2011 04:05 AM
highwhey
Nov 11, 2010 05:53 AM
CHRIS 1.8
Aug 28, 2003 06:01 AM
tha Big EZ
Jul 2, 2003 08:40 AM
