Help! My car won't stop squeeking!
Old Jan 15, 2002 | 06:04 AM
Lui Kang's Avatar
Default Help! My car won't stop squeeking!
I've been trying to figure out what's causing this horrid squeeking noise in my car, but no luck so far
I own a 2000 SiR, and the rear of my car squeeks when I drive over bumps and imperfections in the road. Funny thing is, I can't replicate the problem when the car isn't moving -- only happens when I drive, no matter how much I jump up and down in my trunk
Now, I've heard it can be something as simple as bushings needing some lube to my sunroof. And no, it's not the shocks.
Either way, it's loud, and it's coming from my rear deck. Has anyone else experienced this kind of problem?
Old Jan 15, 2002 | 08:26 AM
bhcvc's Avatar
Default Re: Help! My car won't stop squeeking! (Lui Kang)
I've got the same thing...coming from my rear when I go over bumps and driveways. I'm hoping it's just the bushings that need lubing, but I havent had a chance to test that yet. I'll let you know if I get to do it soon.
Old Jan 15, 2002 | 09:55 AM
TurboSedan's Avatar
New User
Default Re: Help! My car won't stop squeeking! (bhcvc)
Check the rear lower trailing arm bushings. Mine look like they are shredded pretty bad and when I go over a bump I hear a *clunk* from that area of the car.
Old Jan 15, 2002 | 12:19 PM
td04civic's Avatar
Spray some wd-40 on your bushings and then drive, if you don't hear any noise then it's probably your bushings needs.
Old Jan 15, 2002 | 04:29 PM
J T*'s Avatar
Default Re: Help! My car won't stop squeeking (td04civic)
something in the rear of my coupe squeaks all the time and its not even on rough roads, its all the time and nevr consistent or anything. just random squeaks all the time I'm driving.
Old Jan 15, 2002 | 05:30 PM
deepnite's Avatar
if uve got a sway bar..its probably the bushings..use some silicone spray...it also could be ur rear fold down seat if u have one
randomtask77
10
Apr 29, 2010 12:34 PM
chadmasterc
Suspension & Brakes
Jan 18, 2007 07:03 PM
calihondategra19
Suspension & Brakes
Feb 26, 2006 04:43 PM
EK k kay
Suspension & Brakes
Oct 3, 2005 07:30 PM
StinkyTofu
Nov 8, 2001 02:22 PM
