Overheating on newly rebuilt motor
Old Feb 2, 2005 | 05:07 AM
Ecugrad's Avatar
Default Overheating on newly rebuilt motor
Ok, I took my newly rebuilt (D16A6) CRX out for its maiden voyage today. Well I think I put about .1 a mile on her and the temp needle shot up to the H SUPER FAST I dont think I hurt anything, it didnt stay hot very long.
So I felt the radiator cap and it wasnt hot to the touch, so I carefully opened it. Hot steam poured out, no water. Ok, I guess that I had an air bubble in the system. I topped off the radiator and started it without the cap and let it idle for a few mins. No probs, temp needle below halfway. Got just as bout as far as last time and the needle started rising fast again, took it back to the house, felt the cap again and it was just a bit warmer than before, opened it carefully to a nice steam and water shower.
Is this just a case of needing to bleed the cooling system a bit better? OHh yeah, never noticed the fans turning on either.
FYI, the water pump, hoses and t-stat are brand new. The radiator was also flushed well before re-installation
TIA
Old Feb 2, 2005 | 05:11 AM
Magick211's Avatar
Default Re: Overheating on newly rebuilt motor (Ecugrad)
If you positive you have no leaks anywhere, and your thremostat is godd then id go have the system pressure tested
Old Feb 2, 2005 | 06:32 AM
stealth civic's Avatar
Default Re: Overheating on newly rebuilt motor (Magick211)
Open the bleeder bold at try to put more coolant in there. If there is air in the system, the radiator may look full when its really not. Also, feel of your hoses, if the lower one is cold and upper is hot, you may have a bad thermostat.
Old Feb 2, 2005 | 08:52 AM
crxdonwon's Avatar
What did you tighten the head bolts to? Is it a new Radiator Cap? Were the pins that align the head still in it or the block?
Old Feb 2, 2005 | 09:00 AM
Reason's Avatar
Default Re: Overheating on newly rebuilt motor (civicdonwon)
well it could just be your fans since you said you didnt notice those coming on. try running the fans direct and see what happens.
Old Feb 2, 2005 | 09:40 AM
bagpipe goatee's Avatar
the fans only do something when your moving less than like 5 mph, if its overheating while moving, its something else. i go with both pressure testing and making sure the system is bled right
Old Feb 2, 2005 | 09:47 AM
civickiller's Avatar
Default Re: (bagpipe goatee)
it might suck up water for a copule of times before its fully filled. i say try run it a couple more times and then if its still sucking up water, then
Old Feb 2, 2005 | 10:10 AM
sporkcrx's Avatar
Default Re: (civickiller)
Make sure the thermostat isn't in backwards.
Old Feb 2, 2005 | 02:50 PM
Reason's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">the fans only do something when your moving less than like 5 mph, if its overheating while moving, its something else. i go with both pressure testing and making sure the system is bled right</TD></TR></TABLE>
well my car was overheating and it was because of the fans. the needle would move even while i was driving, so thats why i suggested that. it could also be the thermostat.
hatche1
10
Jul 8, 2011 10:29 PM
Empyre JDM
May 11, 2010 12:51 PM
ecks_fourttwo
Jan 24, 2006 07:41 AM
streetracerof06
Dec 8, 2005 03:03 PM
Nocturnal
Dec 7, 2004 02:18 PM
