Assembly lube
Old Jan 15, 2002 | 05:59 AM
MPH's Avatar
MPH
New User
Default Assembly lube
Is it absolutely necessary to apply assembly lube to new cams when you put them in?
Old Jan 15, 2002 | 06:14 AM
HX_Guy's Avatar
Default Re: Assembly lube (MPH)
Ive heard motor oil is fine...isnt tha twhat the Helms recommends? I forget.
Ive always used E.O.S. Assembly Lube when installing any cams.
Old Jan 15, 2002 | 06:23 AM
Mike K's Avatar
Default Re: Assembly lube (HX_Guy)
I sell a graphite-based, high-pressure assembly lube for $6.95 per tube. Works great. I use it on bearings, rod bolts, cams, etc.
Old Jan 15, 2002 | 06:24 AM
MPH's Avatar
MPH
New User
I just used oil and Skunk said oil is fine but I was just checking.
Hey, HX Guy, I'm going back to the dyno next mon. with some adjustments and some more tuning I'll send you the results. The cams pull much harder now since I added the fpr and 2.5 exhaust. I also move the cam settings to +2, +2 and it seems to like it better.
[Modified by MPH, 11:58 AM 1/15/2002]
Old Jan 15, 2002 | 06:25 AM
HX_Guy's Avatar
Good luck man
Im going to go with some ITR cams...at least for the moment being
Old Jan 15, 2002 | 06:26 AM
MPH's Avatar
MPH
New User
93itbh22hatch
34
Feb 7, 2011 02:14 PM
turbodelsolb16a2
12
Nov 30, 2010 12:17 PM
redDAinteg
Jan 6, 2008 11:57 AM
1.8Tities
Sep 25, 2002 04:47 PM
StinkyTofu
Apr 9, 2002 01:29 AM
