rear disc conversion 91 integra to a 96 coupe.. will it work..
Old Feb 1, 2005 | 02:47 PM
pane93civhb's Avatar
Default rear disc conversion 91 integra to a 96 coupe.. will it work..
just wondering if this is a direct swap over like on the eg-ej civics.. search did not work for me thanks for any help.. its for a friends car and he found a good deal on the rear disc trailing arm.. with caliper and rotors.
Old Feb 1, 2005 | 02:50 PM
SOHC4life 96's Avatar
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (pane93civhb)
Yup it'll work. Check the FAQ thread there's about 3 or 4 threads abour rear disc conversions.
Old Feb 1, 2005 | 02:55 PM
stevel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">just wondering if this is a direct swap over like on the eg-ej civics.. search did not work for me thanks for any help.. its for a friends car and he found a good deal on the rear disc trailing arm.. with caliper and rotors.</TD></TR></TABLE>
the rear trailing arms and stuff is the same but with rear disc conversions you need the e-brake cable. I don't think that year integra e-brake cables will work. double check that.
s
Old Feb 1, 2005 | 02:58 PM
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (stevel)
My 93 teg rear disc works fine. I used the e-brake cables from it too. (also a 96 coupe)
Old Feb 1, 2005 | 03:06 PM
2gturboteg's Avatar
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (SOHC4life 96)
just did a 93 teg rear brake conversion onto drkcivic's car about 3 months ago. works great. used integra trailing arms and upper and lower arms and the teg e brake cables and rubber brake lines.
Old Feb 1, 2005 | 05:01 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (2gturboteg)
If your swaping the rear discs, try to get your hands on a proportioning valve from a 99-00 Si, or any 96-00 hatch back. The coup prop valve has different valving for some reason, but the other ones will bolt right in...
Old Feb 1, 2005 | 05:11 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (94eg!)
Please note 94EG, the 4040 valve for a 96 with a disc conversion is from a 99-00 SI ONLY, why would you mention hatches? On 96-00 Civics the ONLY one that came with discs in the back is the 99-00 Si, unless your thinking of the Civic Type-R hatch, but we dont' have that in America.
Old Feb 1, 2005 | 06:01 PM
ek_will's Avatar
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">Please note 94EG, the 4040 valve for a 96 with a disc conversion is from a 99-00 SI ONLY, why would you mention hatches? On 96-00 Civics the ONLY one that came with discs in the back is the 99-00 Si, unless your thinking of the Civic Type-R hatch, but we dont' have that in America. </TD></TR></TABLE>
i thought 96-00 ex's came with an abs option?
Old Feb 1, 2005 | 06:11 PM
pdiggitydogg's Avatar
EEHHHH wrong. (thats my poor attempt at the game show sound)
Hatches, amazingly enough, have the SAME prop valve thats in the em1. So...you dont have to change it on a hatch.
Abs was an option - it used the same prop that was in the hatch
Old Feb 1, 2005 | 06:27 PM
EeeJayEight's Avatar
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (pdiggitydogg)
isnt it that the porp valve on the ex's with abs is the same as em1?
Old Feb 1, 2005 | 07:13 PM
eK9aT10pSi's Avatar
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (EeeJayEight)
the 99-00 SI and the 96-00 DX have the same prop. valve
Old Feb 1, 2005 | 08:36 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: rear disc conversion 91 integra to a 96 coupe.. will it work.. (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight &raquo;</TD></TR><TR><TD CLASS="quote">isnt it that the porp valve on the ex's with abs is the same as em1?</TD></TR></TABLE>
It doesn't matter when you get into ABS, because all ABS cars have 4 wheel disc brakes. The problem is that proportioning valves are NOT interchangable between ABS & NON ABS (they have 4 ports instead of 6)...
Don't forget, most 99-00 Si don't have ABS.
DOHCtR-V
14
Aug 13, 2014 12:32 PM
ek4ferrio
Sep 25, 2006 07:35 PM
Honduh@Love
10
Sep 19, 2005 08:38 PM
93 CX HB
Jan 11, 2005 04:29 PM
skunkcoupe
12
Nov 12, 2004 11:59 AM
