Tempreture gauge not working?
Old Feb 1, 2005 | 12:24 PM
Scrapin4DR's Avatar
Default Tempreture gauge not working?
wus up everybody , i'm new here and i have a question. I gotta 95 civic dx (eg8) it's a sedan , and my tempreture gauge isn't working. does anyone know what the problem could be? any help is appreciated,
Old Feb 1, 2005 | 01:05 PM
Sour Diesel's Avatar
Default Re: Tempreture gauge not working? (Scrapin4DR)
Temperature
Check your temperature sensor
Check the springs
Check the thermostat
Old Feb 1, 2005 | 05:26 PM
ubercerealkiller's Avatar
Default Re: Tempreture gauge not working? (B30M87A)
bump for the bozno
Old Feb 1, 2005 | 05:36 PM
Scrapin4DR's Avatar
what springs did you mean? and where is the temp sensor?
Old Feb 1, 2005 | 05:41 PM
civictildeath's Avatar
there is one here but not sure if this sends signal to gauge or ecu
Old Feb 1, 2005 | 05:45 PM
jbscivichb92's Avatar
Default Re: Tempreture gauge not working? (civictildeath)
no, thats the sensor that kicks the fan on. the coolant temp sensor is located by the thermostat.
Old Feb 1, 2005 | 05:46 PM
Default Re: Tempreture gauge not working? (jbscivichb92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbscivichb92 &raquo;</TD></TR><TR><TD CLASS="quote">no, thats the sensor that kicks the fan on. the coolant temp sensor is located by the thermostat. </TD></TR></TABLE>
so thats what it does. thanks
Old Feb 1, 2005 | 05:54 PM
bump for the bozzie
Old Feb 1, 2005 | 06:06 PM
Scrapin4DR's Avatar
Default Re: Tempreture gauge not working? (ubercerealkiller)
bump
Old Feb 1, 2005 | 06:26 PM
93CivicSiSOHC's Avatar
theres a temperature sender right below your dizy. It has 1 prong on it.
Old Feb 1, 2005 | 06:53 PM
Scrapin4DR's Avatar
Default Re: (93CivicSiSOHC)
bump
Old Feb 2, 2005 | 03:27 AM
Scrapin4DR's Avatar
Default Re: (Scrapin4DR)
bump
Old Feb 2, 2005 | 04:39 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSiSOHC &raquo;</TD></TR><TR><TD CLASS="quote">theres a temperature sender right below your dizy. It has 1 prong on it.</TD></TR></TABLE>
ANd with those two unplugged you will definiely throw a code and your gauge won't work... Just had to trouble shoot that this weekend. A shop broke the sending unit plug, so I had to fix it and plug it back in. They taped it up and hid it in the wiring harness.
Like the didn't think it would effect how the car ran, what a joke.
Old Feb 3, 2005 | 05:17 AM
Scrapin4DR's Avatar
Default Re: (93turbo16)
i gotta check that out and see if mine is unplugged, thanks
bumppppp
Old Feb 3, 2005 | 01:59 PM
Scrapin4DR's Avatar
i checked those 2 sensors or temp senders whatever they're called under the dizzy and they were plugged in, so what would be next to check?
Old Feb 3, 2005 | 02:05 PM
HitEm'Up's Avatar
Thermostat-coolant temp.sensor.would start there
Old Feb 3, 2005 | 02:07 PM
Scrapin4DR's Avatar
Default Re: Tempreture gauge not working? (98JRSChatch)
where would the tem sensor be?
Old Feb 3, 2005 | 02:56 PM
Scrapin4DR's Avatar
bump
Old Feb 4, 2005 | 03:34 AM
Old Feb 4, 2005 | 05:32 AM
Scrapin4DR's Avatar
bump
aziaticvang
Jan 8, 2008 06:33 AM
mamooch
Sep 7, 2007 06:49 PM
qwikz
Mar 2, 2006 07:26 PM
CA6VTEC
Dec 29, 2005 01:13 PM
SPORT INJECTION
Oct 31, 2004 10:36 PM
