92 hatch overheating
Old Feb 1, 2005 | 11:07 AM
weezo182's Avatar
Default 92 hatch overheating
well i getin start it up and with in a few min the coolant temp jusmps all the way up to overhearting, so i turn on the heater and it drops the temp down some but no hot air blows out of the vents, and then after a few min it jumps back up? any ideas? its a 92 HB......
Old Feb 1, 2005 | 11:27 AM
hatchi's Avatar
Default Re: 92 hatch overheating (weezo182)
bleed your cooling system or change thermostat
Old Feb 1, 2005 | 11:41 AM
weezo182's Avatar
Default Re: 92 hatch overheating (hatchi)
ya ive already flushed the system and proabably change the thermastate... any more ideas thanks
Old Feb 1, 2005 | 11:45 AM
D15Bbigred's Avatar
are u smoking at all, or is thier a sweet smell coming from the vents
Old Feb 1, 2005 | 11:53 AM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weezo182 &raquo;</TD></TR><TR><TD CLASS="quote">ya ive already flushed the system and proabably change the thermastate... any more ideas thanks</TD></TR></TABLE>
how do you probably change the thermostat??
its either you did or didnt
if you didnt change it and see what happens they are cheap
Old Feb 1, 2005 | 01:45 PM
Contraband's Avatar
Water Pump.
Old Feb 1, 2005 | 07:57 PM
weezo182's Avatar
Default Re: (LS95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">
if you didnt change it and see what happens they are cheap</TD></TR></TABLE>
i ment to say ill probably change the thermaostat, ya there is some smoke when you push it hard of the light
Old Feb 2, 2005 | 10:43 AM
D15Bbigred's Avatar
ok what color of smoke, do it at ur house have someone stand in back of ur car, and have them tell u if its oil burning or sweet smelling, that would be ur antifreeze
Old Feb 2, 2005 | 02:10 PM
NinjaTurtles's Avatar
Default Re: (EG1racer)
i would agree with water pump or thermostat.
Old Feb 2, 2005 | 02:23 PM
Sasebonian's Avatar
I'd try the thermostat first, since it's a cheap replacement.
Old Feb 2, 2005 | 02:47 PM
SirRevvs's Avatar
Default Re: 92 hatch overheating (Sasebonian)
Could be a few things
1. Air in the cooling system (not likely unless you recently had a cooling service)
2. Thermostat (go ahead and change it out its cheap and you prob need one anyway)
3. Waterpump
4. Clogged radiator (I experienced the same exact prob you were having and this fixed it for me)
5. Blown head gasket (check the color of the smoke coming out your tail pipe, if its white then you may have a problem, check your oil for water bubbles as well)
Old Feb 2, 2005 | 04:26 PM
weezo182's Avatar
Default Re: 92 hatch overheating (SirRevvs)
its a little bit of black smoke.....ill change the thrurmastat and se what happens... ill post the results.... thanks for the help
Old Feb 2, 2005 | 08:14 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weezo182 &raquo;</TD></TR><TR><TD CLASS="quote">its a little bit of black smoke.....ill change the thrurmastat and se what happens... ill post the results.... thanks for the help</TD></TR></TABLE>
That's normal on any honda as old as yours especially if your running any kind of aftermarket programs on your ECU (black smoke=running rich(lots of fuel)). Check out your thermostat and radiator (I think you can have the system pressure tested).
Old Feb 2, 2005 | 08:17 PM
Evs-One's Avatar
Solbros Owns Me
if it gets that hot within just a few minutes, thats bad,
I'd go with head gasket if it's the stock engine. The non vtec SOHC used a composite head gasket which fails really easy.
Old Feb 4, 2005 | 10:28 PM
weezo182's Avatar
Default Re: 92 hatch overheating (Evs-One)
ya i prssure tested it at tech.... i took it to my friends shop he will have it good to go by the monday
invisible
44
Feb 22, 2008 01:33 PM
shortyz21
Oct 2, 2006 03:31 PM
130R
17
Dec 27, 2004 07:07 PM
project-boosteD
Dec 24, 2004 05:53 PM
