Bone stock ls-vtec redline
Old Feb 1, 2005 | 08:23 AM
hondaluva's Avatar
Default Bone stock ls-vtec redline
I'm trying to put together my ls-vtec. Here are my specs:
B16 head (99 si)....Stock
B18B block w/ 117,xxx...stock
I/H/E
Where should i set vtec engagement and revlimiter for this set up? This is a daily driver set up. I need responeses ASAP. I'm trying to order my ecu today.
Modified by hondaluva at 12:57 PM 2/1/2005
Old Feb 1, 2005 | 08:42 AM
goodwinesi's Avatar
Default Re: Bone stock ls-vtec redline (hondaluva)
I'd say your power curve is going to come in about 100 rpms earlier than it previously did. I would set vtec to engage around 4500-4800. And if your cams and valvetrain are stock I would leave the rev limit around 8000 not much more.
Old Feb 1, 2005 | 10:04 AM
97L-esVeeTeg's Avatar
honestly with a bone stock ls bottom end with 117,xxx miles, 7200 maybe 7500 on the tach
Vtec 45-5000
Get some new rod bolts and valvetrain
NathanMorris's Avatar
Default Re: Bone stock ls-vtec redline (97L-esVeeTeg)
anything over the stock LS redline is going to be pushign things without any upgrades at all.
- Nathan
Old Feb 1, 2005 | 12:01 PM
hondaluva's Avatar
bump....thanks for the responses. I was wondering because looking at the dyno charts in importreview.com for similar setups the cars seem to be pulling all the way up to like 8200rpms and i was thinking with out reving at least to 8000 is this whole swap even worth it.... anybody out there running a similar setup that can chime in on this one.
Old Feb 1, 2005 | 12:14 PM
JoeB18R's Avatar
why wouldnt it be worth it? youshould see signifigant gains in torque as well as having a wider power band. RPMs arent everything.
Old Feb 1, 2005 | 12:24 PM
DSRxCandyh2bEG's Avatar
Rev it to around 8200. It should be fine. I did my little brothers lsvtec with stock bottum end and stock 99si head also. only thing difference is that he has stage one skank cams. I do recommend getting valve train and rod bolts just so you can rev higher but 8200 should be ok with your current setup. I think he goes to at least 8200 on the track. I think he might even take it to 8600 but I could be wrong on that...
Good luck
Old Feb 1, 2005 | 06:22 PM
spooncivic1's Avatar
get a VTEC water/oil pump and timing belt and you will be fine to 8k on stock valvetrain
Old Feb 1, 2005 | 06:34 PM
boosted k20's Avatar
Default Re: (spooncivic1)
MAIN thing to get in order to safely rev over 7500 rpms:
Valve springs and ARP rod bolts. stock ls rod bolts will stretch at high rpms and spin bearings, throw rods, damage crank, etc. i wouldnt run anything higher than 7500 is u havent changed the rod bolts to a set of ARP's. if u do change them then u can rev to whatever the stock redline is for the vtec motor, about 8K. get valve springs and u can take it up even more
Old Feb 1, 2005 | 06:41 PM
hondaluva's Avatar
Default Re: (boosted k20)
why do i need valvespring on a head that was designed to rev past 8k in stock form. You guys have convinced me on the arp rod bolts and i'm thinking about acl bearing but i'm not sure what to order. but the whole valve spring thing makes no sense
Old Feb 1, 2005 | 07:07 PM
Default Re: (hondaluva)
disregard what i said about valvesprings. if u get bigger cams then get valve springs. stock springs will do fine. do get arp rod bolts
Old Feb 1, 2005 | 07:12 PM
totsie7944's Avatar
If you get the rods/bolts and apparently you have bigger cams which means valve springs. The only other thing i could think of would be TI retainers.
With all this I say you could safely rev to probably 8600-8800.
vteck1ck
Mar 15, 2010 06:04 AM
Sk8ermane
Feb 17, 2008 09:12 AM
civicgeek133
13
May 20, 2006 02:47 AM
sikcivic95
54
Dec 1, 2004 11:48 PM
93gsrcoupe
May 31, 2004 08:25 PM
