stock b18b1 rev
Re: stock b18b1 rev
Depends on condition that its in.
But 7000 rpm probably the highest I would go ( well highets I went when I had a b18b ).
It really doesnt make more power past that ,so no point going higher .
( in case you have cams, and springs ) then probably will make more power up top, add some arp rob bolts and probably can rev it to your power peak
Re: stock b18b1 rev
Untouched b18b= about 7500 max.
lsVtec b18b= about 8200.
The weak point is the head and rod bolts on a ls. Swap the head with a vtec head and put rod bolts in it and you have an engine that will go to 9000 (with valve train that will handle it). Remeber not to get drawn into the thrill of rpm.If you aren't still making power..... why hold it out.
Re: stock b18b1 rev
Whoever is chipping your' ecu should be able to set a rev limiter for you at a safe point for a internally stock ls-vtec your doing. If you want to rev anywhere past the stock limiter then you should think about building the engine. It would be pointless revving so high seeing as how you aren't getting any power that high as someone already said.
Re: stock b18b1 rev
warrenh32
10-03-2007 01:56 AM
