is it worth using ss for a downpipe if your going to have it ceramic coated ???????
Old Jan 31, 2005 | 01:04 PM
dome's Avatar
Default is it worth using ss for a downpipe if your going to have it ceramic coated ???????
is it worth paying the extra money for ss for making dp if im going to have it ceramic coated?????????? sorry i did not want this to be a poll. sorry everyone.
Old Jan 31, 2005 | 02:26 PM
ExploitedRacing-HR's Avatar
I would say it is. But thats just because i do ceramic coating.
Old Jan 31, 2005 | 03:42 PM
dome's Avatar
Default Re: (ExploitedRacing)
what is the cost for something like the top mount manifold and turbo exhaust housing. would you use stainless steel pipe if you were going to coat it though.
Old Jan 31, 2005 | 03:44 PM
I could do the manifold for $75, and turbo housing for $40, i dont suggest doing the turbo housing however.
Old Jan 31, 2005 | 03:59 PM
dome's Avatar
why not the exhaust side of the turbo? that thing got just as hot as the manifold.
Old Feb 11, 2005 | 05:48 PM
dome's Avatar
Default Re: (dome)
to the top, just tryin to find out if it worth the extra money for ss pipe if your going to have it coated.....
Old Feb 11, 2005 | 06:00 PM
Ekasey's Avatar
Default Re: (dome)
Pointless coating a stainless downpipe
Old Feb 11, 2005 | 06:54 PM
Bailhatch's Avatar
Default Re: (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Pointless coating a stainless downpipe</TD></TR></TABLE>
I agree, that is why I build my manifolds out of mild steel, to keep prices down and ceramic coat them to bring performance up. Just build a mild DP and coat it. I think most people on here are just used to seeing stainless parts and assume that they perform better.
Old Feb 11, 2005 | 07:24 PM
tony1's Avatar
Why not coat the housing?
Old Feb 12, 2005 | 11:20 AM
dome's Avatar
why is it pointless. coating is for a heat issue. im going to have the exhaust housing coated. dont see why you wouldnt.
Old Feb 12, 2005 | 12:15 PM
Bailhatch's Avatar
Default Re: (dome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome &raquo;</TD></TR><TR><TD CLASS="quote">why is it pointless. coating is for a heat issue. im going to have the exhaust housing coated. dont see why you wouldnt.</TD></TR></TABLE>
Lets think about why you would build a stainless exhaust part. Cosmetics and for corrosion protection right? Well, ceramic exhaust coatings act as a thermal insulator but they also provide excellent corrosion protection so using stainless is pointless since you cant see the metal and the coating resists corrosion just like stainless.
As for the turbine housing I agree. A lot of heat is lost through the housing. The only negative I have heard of, but have not seen myself, is reduced seal life on that side of the turbo.
Old Feb 12, 2005 | 04:43 PM
BmCRace.com's Avatar
Default Re: (Bailhatch)
it all depends on how good of a deal you get on stainless. right now i adverage out at saving 50$ by using 304 stainless instead of mild steel for a manifold and downpipe.
Old Feb 12, 2005 | 05:30 PM
Bailhatch's Avatar
Default Re: (BmCRace.com)
good point, but for most people SS is quite a bit more cash. I forgot to mention I was assuming this.
Old Feb 12, 2005 | 09:52 PM
Bail, did you ever notice that stainless steel schedual fittings are cheaper in 304 stainless than in mild steel?
The mild steel pieces are made in USA, and stainless in China.
go figure.
Momentum
Welding / Fabrication
Mar 8, 2010 05:01 PM
jetspeedz
Jul 20, 2009 02:21 PM
Jowee
Jan 2, 2006 02:54 PM
mamaboy
11
Aug 4, 2005 09:19 AM
Red99CivicSi
May 3, 2002 12:51 PM
