identify b16A sirII or sirI or what
Old Jan 30, 2005 | 06:48 PM
xoutlawz00x's Avatar
Default identify b16A sirII or sirI or what
how do i tell the difference?? im looking to buy an engine but i want to make sure waht enginge im buying??
Old Jan 30, 2005 | 06:55 PM
rhdSiR's Avatar
Default Re: identify b16A sirII or sirI or what (xoutlawz00x)
im SURE this has been duscussed here before....
but here are some clues....
sir I = DOHC vtec
sir II =dohc VTEC (dead giveaway if the valve cover is origonal)
different color harness plugs, grey vs. some other color...
plaque on IM on 1st gen
TeamNextGenChris's Avatar
SiRI and SiRII were trim levels in various generations of the civic in Japan.they do not designate between different years of the motors.
you want to know how to distinguish pre OBD(88-91 US civic) motors from OBDI(92-95 US Civic)motors.
main things:
http://tech.hybridgarage.com/tech/b16/index.html
Chris
Old Jan 30, 2005 | 06:58 PM
rhdSiR's Avatar
Default Re: identify b16A sirII or sirI or what (TeamNextGenChris)
he is refering to SiR II motors (1992 up vtec B16A's) to distinguish between SiR I (Pre 1992 vtec B16A's)
Old Jan 30, 2005 | 07:01 PM
Default Re: identify b16A sirII or sirI or what (rhdSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdSiR &raquo;</TD></TR><TR><TD CLASS="quote">he is refering to SiR II motors (1992 up vtec B16A's) to distinguish between SiR I (Pre 1992 vtec B16A's)</TD></TR></TABLE>
yes,i realize that.SiRI and SiRII DO NOT distinguish between different years of the motors.there are SiR and SiRII trim levels in both the EF and EG generations.
read the link-it lists many ways to tell the difference in the OBDI and pre-OBD B16s.
many people use the SiRI and SiRII titles to designate between the two generations of motors,but it's not accurate:
EF lineup:
http://www.honda.co.jp/HOT/Mod....html
EG lineup:
Chris
Modified by TeamNextGenChris at 4:26 AM 1/31/2005
Old Jan 30, 2005 | 07:36 PM
well the motor is out of the car and it has a gsr valve cover and the head says 1991.. is there any way esle i can tell the differnece
Old Jan 30, 2005 | 08:16 PM
dantastic's Avatar
Old Jan 31, 2005 | 05:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x &raquo;</TD></TR><TR><TD CLASS="quote">well the motor is out of the car and it has a gsr valve cover and the head says 1991.. is there any way esle i can tell the differnece</TD></TR></TABLE>
look at the colors of the sensor connectors,as well as the intake manifold differences listed in the above link.
Chris
Old Jan 31, 2005 | 05:58 PM
del_orson's Avatar
1991 is the first year of SIR2. Also it should only have 1 O2 sensor if it is a SIR2. All SIR2 come with hydralic trannys but this will not tell you the truth.
Old Jan 31, 2005 | 06:02 PM
JDMisGOOD's Avatar
Default Re: identify b16A sirII or sirI or what (del_orson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson &raquo;</TD></TR><TR><TD CLASS="quote"> All SIR2 come with hydralic trannys but this will not tell you the truth.</TD></TR></TABLE>
not a true statement i have seen SiR-II with cable tranny's....i have one
Old Jan 31, 2005 | 07:09 PM
del_orson's Avatar
that is why i said it may not be true if you have a cable tranny
Old Feb 1, 2005 | 04:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson &raquo;</TD></TR><TR><TD CLASS="quote">1991 is the first year of SIR2. Also it should only have 1 O2 sensor if it is a SIR2. All SIR2 come with hydralic trannys but this will not tell you the truth.</TD></TR></TABLE>
look at the links i provided.this is straight from the Honda of Japan website.there was an SiRII in the EF series,of which NONE have hydro trannies.also notice that each model has listed the year it debuted.the SiRII EF came out in 1989.
Chris
dragonkx
Feb 26, 2022 08:11 AM
hondahead21
May 4, 2008 04:52 AM
EkCivicRunner
May 15, 2006 12:34 PM
k193sup
May 13, 2002 08:45 AM
td04civic
Apr 19, 2002 10:51 AM
