lsturbo +gsr oil pump?
Old Jan 14, 2002 | 03:17 PM
quikrpm'z's Avatar
Default lsturbo +gsr oil pump?
is this a good idea or bad? Im currently using the stock pump, i only get reading of 10-12psi at idle, and max psi i ever see is 45-50psi. I know the turbo doesnt like too much pressure, but i feel that my engine is starving for oil. any ideas?
Old Jan 14, 2002 | 04:44 PM
Evil DOHC's Avatar
Default Re: lsturbo +gsr oil pump? (quikrpm)
Yes you can do it. Its a little better than an ls. Type r or gsr should fit. Personally you can do that. But you will have to use the gsr timing belt. So timing belt and oil pump should fit. You might as well throw on a gsr water pump.
EVIL
Old Jan 14, 2002 | 04:47 PM
Turbo00's Avatar
New User
Default Re: lsturbo +gsr oil pump? (Evil GS-R)
well i have a b16 and want to use a gsr water pump will i have to change out to a gsr timing belt also
Old Jan 15, 2002 | 02:00 AM
qwkteg125's Avatar
where do you have the gauge tapped at? the helms manual states that if tapped from the oil pressure switch, you should see about 10psi min at idle & 50psi min at 3k rpms. so if that's where your gauge is your #'s do seem a bit low.
if you do switch to a b18c oilpump, you don't need a b18c belt, you only use that when using a b18c waterpump.
Old Jan 15, 2002 | 03:25 AM
Evil DOHC's Avatar
Default Re: lsturbo +gsr oil pump? (qwkteg125)
If you go and change the oil pump, u might as well change the water pump on the ls. That is why i said you needed a gsr timing belt. I have done this many times on most ls's.
EVIL
Old Jan 15, 2002 | 05:31 AM
Ri5e's Avatar
I see 15-20 PSI at idle and max out at 70 PSI at full throttle when tapped at the oil location next to the filter. I have since relocated mine because the brass T fitting broke off! Now its up on top, a la Endyn style. It reads 10 PSI at idle and around 60 PSI at full throttle
Old Jan 15, 2002 | 10:05 AM
rtype11's Avatar
you cannot use this on a 96 or newer LS without removing the CFS as it cannot be attached to the GSR oil pump. stock computer must have this input, so then you must ground it out somewhere else, LS make plenty of pressure but we dont have any VTEC assembly to engage or squirters so just maybe get a new gear or shim yours for more PSI.
KdF
Mar 10, 2009 05:36 PM
The Si
Feb 14, 2007 03:26 PM
The Si
Feb 13, 2007 01:29 AM
jDMJeRk
Jan 27, 2004 10:45 AM
Hondasaurs
Feb 25, 2003 04:20 PM
