where is the fuel pump on my da
greeeat thats what i was not hoping for. does anyone know of a link that will tell me how to do it? i dont have a helms or service manual for it. thanks for the replys.
I have the Haynes repair manual for 90-93 tegs and dont know what Id do without it. Detailed instructions for anything you wanna know. Get it at amazon.
But if you dont, relieve pressure from the fuel system, at the fuel filter on firewall in engine bay.
Disconnect negative battery terminal
drain the tank and dump in your neighbors flower bed( I left enough gas in to get to a gas station)
remove all lines and electrical connections from tank.
I put a wood block on a jack and jacked it up to the tank.
loosen the two straps that hold the tank untill you can lift and remove them.
Drop the tank with the jack
Remove the fuel pump and replace with the new one, use common since its not that difficult.
You might want to have a friend position and hold the tank while you reinstall the straps, I did it by myself( balance it on the jack as you jack it up, pain in the ***)
Reinstall everything and start car
Check for leaks
Thats pretty much it, I hope I didnt leave anything out.
Its really not difficult
Check for leaks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcoupe01 »</TD></TR><TR><TD CLASS="quote">drain the tank and dump in your neighbors flower bed </TD></TR></TABLE>
bwhahaha.. that was rather amusing.
thanks im gonna do this tomorrow.
Im definitely gonna dump the gas on the neigbors yard
they killed my cat. since i didnt get a write up when i searched for it ill take pics (maybe)
**EDIT**
heres a link for a good g2 forum and a post i found
http://www.g2ic.com/forums/sho...moval
Modified by hndakd at 5:24 AM 1/31/2005
they killed my cat. since i didnt get a write up when i searched for it ill take pics (maybe)**EDIT**
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcoupe01 »</TD></TR><TR><TD CLASS="quote">Im on G2IC all the time, awesome site</TD></TR></TABLE>
try http://www.g2ic.com . They have great articles on there.
I reccomend buying new straps and bolts for your tank from acura. They are usually pretty rusty and non-cooperative. It cost like ~30 bucks for these parts and made the install smooth.
