Any advice for a turbo virgin?
Old Jan 30, 2005 | 01:08 PM
blackcoupe01's Avatar
Default Any advice for a turbo virgin?
I am installing a turbo kit(Full Race stage2)on my DA Teg and have no prior turbo experience. I know how everything works but am curious about the actual install, once everything is complete can I start the car to check for oil or vacuum leaks before I trailer it to my tuner? What is a good way to make sure there is no deris in the turbo? Thanks for any advice.
Old Jan 30, 2005 | 01:38 PM
djbutler007's Avatar
Default Re: Any advice for a turbo virgin? (blackcoupe01)
check this out
http://www.deepstaged.net/installs.htm
Old Jan 30, 2005 | 02:05 PM
joek84's Avatar
Default Re: Any advice for a turbo virgin? (djbutler007)
don't worry, the turbo should get you laid
Old Jan 30, 2005 | 02:10 PM
pubestripe's Avatar
Default Re: Any advice for a turbo virgin? (joek84)
ahahahaha lol. yeah dont go into boost though b4 tuning, but turning it on is fine to check for leaks!
Old Jan 30, 2005 | 02:15 PM
Rory Breaker's Avatar
Make sure there is no debris in the turbo? Im not sure the question...if there is, you would have had to put it there. If then turbo spins freely before installation, chances are its "debris-free"
Once everything is complete, if your fuel system is setup to adequately idle the car then sure, you can start it up to ensure that you dont have any oil leaks or vacuum leaks somewhere. Although with a turbo install, there isnt much you can do to botch vac lines.
The 2 things that typically occur are minor oil leaks after the install, if you didnt tighten things down or used the wrong fittings, and boost leaks, which if you dont drive on it beforehand, will figure out when you bring it to the tuner.
When I fired up my car for the first time:
1) I used the wrong fitting for the feed line, it cracked upon installation and subsequently couldnt hold pressure (duh)
2) Blew couplers a few times, took a bit to get them on right and tight.
3) Creeped like crazy due to open downpipe and drag manifold
Thats about it.
Old Jan 30, 2005 | 02:44 PM
whoneedzvtec's Avatar
Default Re: Any advice for a turbo virgin? (newgsrdriver)
wrong u didnt boost creep due to a drag manifold and an open down pipe. it was ur wastegate. get a tial and throw away that pos turbonetics
Old Jan 30, 2005 | 02:47 PM
pubestripe's Avatar
Default Re: Any advice for a turbo virgin? (lsturbotegbb250)
well, drag mani's have crazy *** boost creep 15psi and up... so it could have been that. but yea, turbonetics wastegate gets a big thumbs down from me
Old Jan 30, 2005 | 06:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturbotegbb250 &raquo;</TD></TR><TR><TD CLASS="quote">wrong u didnt boost creep due to a drag manifold and an open down pipe. it was ur wastegate. get a tial and throw away that pos turbonetics</TD></TR></TABLE>
I was running a Tial 35mm.
Old Jan 30, 2005 | 06:47 PM
pubestripe's Avatar
then it was the damn drag mani!!!! those mani's are piles of sheet!
Old Jan 30, 2005 | 07:12 PM
I installed my walbro pump and drove it around first to make sure everything was cool before I started the rest of the install. The hondata and injectors are going in when I get tuned. Is this OK?
Old Jan 30, 2005 | 07:33 PM
WHITE DEATH's Avatar
If you have that nice *** turbo kit and Hondata i dont think it can get any better.
Old Jan 30, 2005 | 08:50 PM
mpintegra96's Avatar
i spent alot of time reading everything in the forcedinduction forum and using search engines that helped me and its all about the tune
Old Jan 31, 2005 | 12:41 PM
SilentHill's Avatar
thanks for the link dude explains alot
ej1252
Oct 30, 2007 01:51 PM
sohc_turd
Mar 1, 2006 11:48 AM
sykotic
Mar 15, 2005 03:05 PM
kj98r
May 16, 2004 03:16 PM
yellowbuffalo
Feb 7, 2002 07:10 PM
