How do you tell if a ECU is Manual or Auto?
I have a few ECUs laying around and I know that by useing the code on the side of the ECU you can tell if an ECU is manual or Auto. However I also know that the number depends on the year and the model of ECU. Is there a site that you can type in the number and it will tell you or can anyone lead me to some info on how to tell?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1082468</TD></TR></TABLE>
That thread is sorta useful as long as what the second person says is true. The pic that is posted however is totally false at least for a P75 and a P06. I will post pics as soon as the cams batteries charge.
Here is the pic of an Automatic P06 according to the 50+ rule.
According to the same rule I also have a manual P06 that ends in A02 and it does not have a single one of the little black tabs. So I would stick with the 50 and over being Auto and under being manual and I would throw that pic in the trash becuase it does not hold up for all the ECUs that are lited in the pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 »</TD></TR><TR><TD CLASS="quote">According to the same rule I also have a manual P06 that ends in A02 and it does not have a single one of the little black tabs.</TD></TR></TABLE>
no yours ends in A52 and there are two of those "black tabs" circuits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 »</TD></TR><TR><TD CLASS="quote">Here is the pic of an Automatic P06 according to the 50+ rule.</TD></TR></TABLE>
yes the pic you gave us is an auto
yes the pic you gave us is an auto</TD></TR></TABLE>
Yes the pic I posted was an AUTO however if you note the fact that I said also meaning that I have more than one I ALSO have one that ends in A02 and it has none of the black tabs.
please note location of the fingers pointing to specific area. only pointing to 2 (two, deuce) circuits (black tabs)
37820-P75-A53 981-202919 98 Acura Integra LS 2 Automatic
ECU/TRANSMISSION
A50 and up Automatic
A61 CVT
A under 50 manual
L under 50 manual
I'm pretty sure this holds true for all
ECU/TRANSMISSION
A61 CVT
A under 50 manual
L under 50 manual
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice »</TD></TR><TR><TD CLASS="quote">I'm pretty sure this holds true for all
it does he is just being difficult
</TD></TR></TABLE>it does he is just being difficult
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">please note location of the fingers pointing to specific area. only pointing to 2 (two, deuce) circuits (black tabs) </TD></TR></TABLE>
Funny 2 fingers but 3 tabs in that pic and only 2 tabs in the pic that I took. I said that the 50+ rule was the way to go I don't see how I am being difficult I am just saying that the pic does not hold true for the ECUs that are listed. Here is the ECU that ends in A02 in the pic that was posted there was one finger and one black tab but if you look you will not find a single blak tab.
You would get the auto lock up solenoid code, number 19. And it does pretty much hold true for all ecus, I have 2 A52 sitting here and they are auto and on A02 and it is manual. THe easiest way to tell is to just open them up.
JokerX-1.6T
Feb 12, 2007 07:24 PM
GiMpInThaCiv
Jul 15, 2006 04:27 PM
sohc_freak
15
Apr 22, 2006 03:26 PM
cjwarren4dcivic
Feb 1, 2006 11:17 PM
