Cluster Swap done!
Old Jan 29, 2005 | 05:31 PM
tranquil's Avatar
Default Cluster Swap done!
I finally did my cluster swap. Nothing too special, it's from an EX and it had indiglo gauges on it so that was an extra hurdle (yes I kept them, no I'm not into flashy rice stuff, but I really wanted white gauges and didn't want to spend double for JDM).
So this post is to show the new gauges and to thank everyone who posts any information on this forum because they helped me immensely in the swap and I'm sure in any future projects as well.
One very informative post showed how to roll back the odometer (since I wanted to keep the white gauge faces and not have to remove the needle) but that didn't seem to apply to the 95 DX/EX odometers I had sitting in front of me.
They had plastic melted after they were put in place to prevent anyone from manipulating them without hassle or evidence. I could roll back the miles but very slowly and when you're looking at 30k difference it would take me all week! So I pulled the needle and swapped the odometers themselves. I think I have the needle close to accurate but I'll probably have to pace someone I know to see how close it truly is. (***any advice would be awesome***)
I also painted the needles orange so they would stand out from the white faces better and I think it looks really good that way. The indiglo actually matches the USDM lighting scheme with the rest of the components (blue tones).
Thanks again Honda-Tech contributors.
Old Jan 29, 2005 | 05:36 PM
BlueIntegraBoy's Avatar
Default Re: Cluster Swap done! (tranquil)
Wasn't so bad, was it?
Old Jan 29, 2005 | 05:41 PM
tranquil's Avatar
Default Re: Cluster Swap done! (BlueIntegraBoy)
It wasn't too bad solely because of the posts on the board where I learned...
1) Indiglo should tap into the Red/Black wire and ground to the body
2) How to swap the odometers / remove needles, because there is no way I would have pulled so hard on that needle if people didn't post that it just really really hard the 1st time.
3) The hidden screw behind the emergency blinkers
Those three things, especially the 1st two could've made it nearly impossible to do the swap if I didn't know about it.
Old Jan 29, 2005 | 05:43 PM
JDMisGOOD's Avatar
congrats it looks good
Old Jan 29, 2005 | 06:26 PM
endlesswinterco's Avatar
Default Re: Cluster Swap done! (JDMisGOOD)
indalgo?
Old Jan 29, 2005 | 06:42 PM
HATCHingMN's Avatar
looking good
Old Jan 29, 2005 | 07:13 PM
703_Sleeper's Avatar
Default Re: Cluster Swap done! (HATCHingMN)
Good Work
graffini
Feb 13, 2010 02:49 PM
95 GSR B20VTEC
Oct 29, 2008 11:43 PM
ctr status
Mar 9, 2008 12:13 PM
99_EK9Civic
Jun 2, 2005 02:01 PM
CivicEG R
15
Aug 31, 2004 07:44 AM
