ZC No start
Old Jan 29, 2005 | 03:34 PM
SwissChEz82's Avatar
Default ZC No start
Alright, after finally getting my zc swap all put together i can't figure out why it won't start, it cranks but won't turnover. Does anyone have any ideas for where to start checking?
Old Jan 29, 2005 | 03:37 PM
crxnj's Avatar
Default Re: ZC No start (SwissChEz82)
Getting any spark or fuel?
Old Jan 29, 2005 | 03:40 PM
Getting fuel, found out the hard way when i noticed fuel shooting out the banjo fitting on the fuel rail cause i didn't put the little metal gasket in. Not sure how to check for spark though.
Old Jan 29, 2005 | 03:43 PM
crxnj's Avatar
Have someone crank the motor and take off one of the spark plug wires on the disributor while cranking..You should see spark..If there is no spark the 1st thing to do is check the coil..Make sure its installed correctly and not fucked up
Old Jan 29, 2005 | 03:46 PM
Default Re: ZC No start (Mr.speaker)
Are there any other factors? I haven't wired the CAS and I haven't pluged up that vacuum hose in the back of the engine compartment.
Old Jan 29, 2005 | 04:36 PM
any other ideas?
Old Jan 29, 2005 | 04:47 PM
Riceburner247's Avatar
You'll need to check timing as well. Fuel and spark don't mean **** if they aren't meeting each other at the right time.
Old Jan 29, 2005 | 05:07 PM
pyro_freak8's Avatar
also, you need the same engine harness off of your stock engine... when i did my swap i had an si harness on my zc at first and had the same problem, when i changed to my hf harness on the zc it started right up... who would have though.... that would have saved me like 10 hours of trouble shooting
Old Jan 29, 2005 | 05:48 PM
Default Re: (pyro_freak8)
I have the same harness already. Initially I'd have to say its the spark, it just seems like I'm not getting a spark. I had to repin my dist. harness so I'll check that first thing tomarrow, I want to drive this thing.
Old Jan 29, 2005 | 06:43 PM
also check the two white wires on the dizzy, you may need to try switching them...
Old Jan 29, 2005 | 06:53 PM
NCRXSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwissChEz82 &raquo;</TD></TR><TR><TD CLASS="quote">Are there any other factors? I haven't wired the CAS and I haven't pluged up that vacuum hose in the back of the engine compartment.</TD></TR></TABLE>
You haven't wired the Cam Angle Sensor (CAS)?
Old Jan 29, 2005 | 11:43 PM
CRX SIt's Avatar
Default Re: ZC No start (NCRXSi)
if you got it from h motors check your injectors i did a swap 2 weeks ago and got it all done and nothing pulled the injectors out and they were filthy so i swaped them with the ones in my d16a6 and it was good
Old Jan 30, 2005 | 04:03 AM
Default Re: ZC No start (CRX SIt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX SIt &raquo;</TD></TR><TR><TD CLASS="quote">if you got it from h motors check your injectors i did a swap 2 weeks ago and got it all done and nothing pulled the injectors out and they were filthy so i swaped them with the ones in my d16a6 and it was good </TD></TR></TABLE>
Really? I did get it from H Motors.
I went down and wired the CAS and tried again last night, no luck.
Old Jan 30, 2005 | 09:01 AM
CRX SIt's Avatar
yea i had bad injectors i swapped them out and it was all good,,,,
by the way when i got my motor i picked it up from h motors i sw your zc on a pallet getting ready to be shipped
Old Jan 30, 2005 | 09:31 AM
Cool, how bad were the injectors? Would injector cleaner have cleaned them?
Old Jan 30, 2005 | 03:24 PM
Cleaned the injectors, it fires but won't run, sounds like the timing is off. wer wer wer thump wer wer thump thump wer wer wer thump thump thump-thump thump-thump thump...thump, almost like a v8
Old Jan 31, 2005 | 05:03 PM
It starts, it runs and it revs really high when you first start it.
Old Jan 31, 2005 | 05:58 PM
dubzz24's Avatar
What got it running?
Old Jan 31, 2005 | 06:15 PM
DJ_SaNdOz's Avatar
make sure that the dizzy wires are correct & the cas is correct as I had that same issue when i did my swap.
Old Jan 31, 2005 | 06:42 PM
Default Re: ZC No start (DJ_SaNdOz)
its not the dizzy i think its the eacv
Old Feb 2, 2005 | 06:37 PM
QuickRexSi21's Avatar
make sure your cables are in the right place and are still in good shape. i got mine from hmotors as well, everything was fine. make sure that the distributor is good. and the cap and rotor is in good shape. make sure its wired right. if you are in the L.A area, email me. i got spare ZC parts and im pretty handy when it comes to that. ive gone thru two in my rex and still got one in good shape. Quickrexsi21@aol.com
eazye5591
Dec 19, 2012 05:26 AM
GhostInTheShell
May 30, 2006 02:31 PM
mustninty
17
May 24, 2004 12:52 PM
MattPM0000
11
Mar 29, 2004 02:39 PM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
