O-ringing a block
Old Jan 29, 2005 | 12:14 PM
9seccivicsi's Avatar
Default O-ringing a block
I am building a gsr motor and i have the old style darton sleeves similar to AEBS sleeve style...... I had a machine shop install a metal o- ring of .043 thickness .... i was wondering with this size o ring do i have to put a resessed groove in the head? also would it be a good idea to spray the head gakset with a copper spray? I am using a MLS cometic head gasket by the way?
thank you
Old Jan 30, 2005 | 06:22 AM
NJIN BUILDR's Avatar
Default Re: O-ringing a block (runsnines)
With the o-ring installed it should only be about .006" or so above the deck.you don't need to cut a recess in the head.I always use copper spray and have never had a problem.Not positive it works but I'm sure it doesn't hurt.
Glenn
Old Jan 30, 2005 | 06:45 AM
Default Re: O-ringing a block (NJIN BUILDR)
cool thank you .... any one else have a opinion on this?
Old Jan 30, 2005 | 07:36 AM
PrettyLude's Avatar
talk to earl, he builds alot of engines
Old Jan 30, 2005 | 09:07 AM
T4eg's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">talk to earl, he builds alot of engines</TD></TR></TABLE>
id agree
Old Jan 30, 2005 | 03:11 PM
talked to earl ealier he said shouldnt have to.. so i guess i dont
Jdmb16sir2
Oct 26, 2007 12:23 PM
VVV
Jul 30, 2007 03:37 PM
igo4bmx
Sep 25, 2006 09:05 AM
sporkcrx
Jul 3, 2003 10:44 PM
EG-cellent
Apr 14, 2003 06:01 AM
