convert an obd1 or obd2 distributor to obd0?
Old Jan 29, 2005 | 09:00 AM
itsJDMyo's Avatar
Default convert an obd1 or obd2 distributor to obd0?
my friend just bought a 90' civic with a b16 swap. the only thing missing is the distributor. it was an obd0. but we can't seem to find any obd0 distributors around here. but he has an obd1 from a b16a2, is there a way we can re-wire it somehow, so it will be obd0??
Old Jan 29, 2005 | 10:03 AM
itsJDMyo's Avatar
Default Re: convert an obd1 or obd2 distributor to obd0? (itsJDMyo)
Old Jan 30, 2005 | 06:12 PM
Blown90hatcH's Avatar
If you want to run the OBD1 distributor, you need to run the OBD1 ecu and will need one of these OBD0-1 conversion harnesses to do so.
http://www.jkobdconversionharness.com/0to1.htm
Jason
Old Jan 30, 2005 | 06:56 PM
HondaFig's Avatar
Default Re: convert an obd1 or obd2 distributor to obd0? (Blown90hatcH)
From what I've heard the only differenc in the dist. is the teeth on the cam position sensor so all that you should have to do is change the gear and sensor for the cam postion to OBD0, but I havn't tried one yet.
Old Feb 4, 2005 | 06:18 AM
Magick211's Avatar
Default Re: convert an obd1 or obd2 distributor to obd0? (HondaFig)
I have a obd0 b16 dizzy for sale make offer
ryanangelo212
Mar 18, 2013 12:23 AM
nycpatron
Mar 29, 2010 09:52 PM
crazyef8
10
Apr 20, 2009 09:44 PM
ej8
Jan 27, 2005 10:56 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
