ecu keeps on burning? after a new swap
ok here is the deal just finished a 1993 civic with a d15b sohc vtec now the problem is the cel comes on rite away when the key is switch to ignition on and the car wont start ill crank but wont start over and on top of that its burns up ecus so far burn 2 of them already check the codes and it threw a code intake air temp sensor which is a code 10 but everthing is hooked up what can it be even check all the wires no bad ones seen so far so any sugestion would help thanks in advance...
Re: ecu keeps on burning? after a new swap (superjunprelude)
if your smoking ecu's I'd really be inclined to think you have some wires pinched/wrong I'd go back over your wiring....a bad a sensor shouldn't smoke or burn an ecu...
1 Post
Re: ecu keeps on burning? after a new swap (foz)
are, if your smoking ecu's this def is not a sensor overload, or anything like that. If you can't find a bad wire, replace the harness if you can, double check all your connections, fuse types, and grounds. Other than that i dunno....
bump
bump
