DRaG3 turbo kit..FMU, fuel pump and boost gauge check..
I have a DRAG3 kit on my '00 si and i just wanted to make sure i had everything hooked up rite.
Ok, the fuel pump goes on that line from the stock fuel filter to the fuel rail?
The fMu hooks up to the fuel line going to the stock fuel pressure regulator?
Boost gauge tees off to the stock fuel pressure vacuum?
Ok...where do i tee off the vortech fmu vacuum?? And what vacuum hooks on the side of the turbonetics wastegate and the side of the compressor on the turbo.
Any help would be greatly appreciated..thanks
If it's an inline fuel pump it goes after the filter but before the fuel rail.The fmu goes after the fuel rail (and fpr) and splices in the fuel return line.The boost gauge can be t-'d off of any vacuum/boost port along with the fmu.I have mine coming from the port on the intake manifold.Then take ashort hose and connect the wastegate and the compressor via the smal ports.When i installed my boost controller i drilled a hole in the charge pipe after the intercooler and ran that to my boost controller then to the wastegate and caped the compressor port off.
vtec_killer_
Feb 17, 2008 10:06 AM
