NEED HELP WITH IGNITION AND TIMING ON B18B1 MOTOR iN 93 HATCH
Old Jan 28, 2005 | 12:58 PM
eg6_rick's Avatar
Default NEED HELP WITH IGNITION AND TIMING ON B18B1 MOTOR iN 93 HATCH
i just finished an LS motor swap with my 93 hatch. I set the timing at the white markings with timing light. The first time this happened, i also readjusted the air fuel ratio. Now every time i go to start my car, it just cranks crazy as if it needs a new starter or battery jump or something. I readjusted the timing again at the red mark, this time it starts okay but the rpm is way above 1 (this makes my car eating a lot of fuel). Anyone has any other suggestions?? i need my car to start up again (normally)
Old Jan 28, 2005 | 09:44 PM
chameleon's Avatar
Default Re: NEED HELP WITH IGNITION AND TIMING ON B18B1 MOTOR iN 93 HATCH (eg6_rick)
hwo did you adjust the air/fuel you speak of. i think thats your problem right there, and um put the timing back on the white mark, on the red lines its like 10 deg retarded or something.
Old Jan 28, 2005 | 10:07 PM
krazyDOHC's Avatar
Default Re: NEED HELP WITH IGNITION AND TIMING ON B18B1 MOTOR iN 93 HATCH (chameleon)
Can't figure out what you are saying but this MIGHT help....there are 4 marks on the pulley, the one by itself is top dead center. Line up the line by itself with the mark on the plastic black cover and make sure your cam gears are lined up (9' o clock 3') with the word top on top ...Then figure out the ignition timing after you have the cam timing correct.
Old Jan 28, 2005 | 10:13 PM
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">how did you adjust the air/fuel you speak of?</TD></TR></TABLE>
Are you sure you set the timing properly?
Setting ignition timing
1990civicdx
Jul 17, 2018 06:13 PM
lilshady6796
21
Mar 31, 2009 09:18 PM
decent
Sep 4, 2005 09:43 AM
eg6_rick
Feb 1, 2005 04:05 PM
King_j
Aug 14, 2003 07:40 PM
