NEED HELP WITH 93 HATCH WITH LS SWAP!!!
i just finished a LS swap into my hatch. The timing is set at the white mark. I adjusted the air-fuel ratio as well. Every time i go start it up the car just cranks crazy as if it needs a new starter or jump from another battery. I then readjusted the white timing mark to the red mark, this time the car starts up with no problem, but the RPM is setting way above 1 (this makes the car eating a lot of fuel). I don't know what to do now. Is it the timing? is it something to do with the starter, battery?
TSPeed Factory
Re: NEED HELP WITH 93 HATCH WITH LS SWAP!!! (eg6_rick)
i don't see why you would have to mess with the A/F ratio if you're just swapping it in. just run a stock LS ecu and see if it starts up.
Wait a min... i didn't adjust the air/fuel ratio. What i adjusted was the idle on the intake manifold...what was i thinking ....anyhow, anyone in here still know whats wrong with the timing and idling? it seems like the ignition needs some sort of memory.
ahtublao
12-22-2010 05:21 AM
Lao17
11-17-2010 05:12 PM
kevlh18
18
01-20-2006 04:43 PM
eg6_rick
01-28-2005 10:13 PM
