Switch Wiring
Old Jan 28, 2005 | 07:43 AM
fe519's Avatar
Default Switch Wiring
Hey everyone... I just got a quick question. Me and my friend is trying to hook up a switch, just a on off switch which has 3 prongs coming out of it. Can someone confirm that we are hooking this up right? ok... from the switch, 1 wire goes straight to the battery, 1 goes straight to the power wire on the motor, and 1 goes to the ground on the battery. Im pretty sure this is right but when I put in a fuse, it just pops. Thanks for the help! I really appreciate the advice.
Old Jan 28, 2005 | 08:19 AM
JimBlake's Avatar
Default Re: Switch Wiring (fe519)
Lose the connection back to ground. You don't want that at all.
You're only gonna use 2 of the terminals. Common & one of the others. Which one you pick depends on whether you want it to be normally closed or normally open. In other words you get to decide which way is 'on'.
siblues
Audio / Security / Video
Jan 4, 2011 10:30 AM
boostedb20z
Mar 23, 2009 05:59 PM
underpressure02
Apr 23, 2007 08:42 AM
Driven
13
Jan 26, 2003 11:45 AM
Splat
Jan 7, 2002 07:00 AM
