235/60/15 M&H/ET streets (pictures on car)
Old Jan 28, 2005 | 04:19 AM
DontBlink's Avatar
Default 235/60/15 M&H/ET streets (pictures on car)?
does anyone have pictures of these tires on there cars? id like to see how big they actually look.im considering getting a set of one of these tires for this upcoming year. i currently run on 225/50/15 BFG drag radials (1.96-1.98 60' times) but after that traction is non existant till 3rd gear. so im looking for something with a little more stick.
Modified by DontBlink at 10:00 AM 1/28/2005
Old Jan 28, 2005 | 04:49 AM
DaveF's Avatar
Default Re: 235/60/15 M&H/ET streets (pictures on car)? (DontBlink)
lol. i have a set of bfg 235 60 15's on my car. they are absolutely huge. also, be sure that you have a good suspension, cause i ran mine with stock shocks for a bit and it cut into the outer edge of the tire.
i dont want to take a pic of it right now, cause the car is hideous.(no engine, no bumper on, no headlights, and 1 fender is dented where i kicked it in.)
there is a yellow itr from jersey running these tires..lemme find it..
http://forum.vwsport.com/dload...=3751
http://forum.vwsport.com/dload...=3750
http://forum.vwsport.com/dload...=3749
hatch vs itr both on 235/60/15 m&H
http://forum.vwsport.com/dload...=3745
Old Jan 28, 2005 | 05:16 AM
SlicksMH's Avatar
Default Re: 235/60/15 M&H/ET streets (Dturbocivic)
Fernando AKA Godfatherofboost has a video. He ran a 10.33 on that Dot.
John@M&H-Hashims
DaveF's Avatar
here is a shot of my car.
here is the yellow itr.
Old Jan 28, 2005 | 06:34 AM
underpressure02's Avatar
i can vouch for dave. His car looked like **** with those tires on it. The car looked beyond 4x4.
Old Jan 28, 2005 | 06:36 AM
smokey2.0's Avatar
Default Re: 235/60/15 M&H/ET streets (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">i can vouch for dave. His car looked like **** with those tires on it. The car looked beyond 4x4. </TD></TR></TABLE> true, they look jacked up. those are some tall tires
Old Jan 28, 2005 | 08:28 AM
DontBlink's Avatar
Default Re: 235/60/15 M&H/ET streets (smokey2.0)
ok guys thanks for the info,pictures,clips etc. i'll probably just end up getting another set of 225/50/15 BFG's.
sure would be nice if M&H made a 225/50/15(hint hint )
Old Jan 28, 2005 | 09:42 AM
DaveF's Avatar
the m&h tires on the itr seemed to fit really well. i liked the car alot. the tires looked comfortable in the wheel well.
Old Jan 28, 2005 | 12:16 PM
PM-Performance's Avatar
i think they look good on that pic with the civic. **** if they hook who cares how they look. they are 26" od though arent they? Thats a big tire, but id run em .lol
Old Jan 28, 2005 | 01:45 PM
DIRep972's Avatar
Smarter than you
Default Re: 235/60/15 M&H/ET streets (itr206)
Here you guys go,
Formula for finding height of tire:
(Width x Profile as decimal)2 + Rim Size = Height
Convert the width into inches- 235mm = 9.251 inches
Soo for a 235/60/15 you get;
(9.251" x .60)2 + 15" = H
(5.55)2 + 15 = H
11.1 + 15 = H
26.1 = H
235/60/15 = 26.1 inches tall
I don't think the tire is as tall as what the specs indicate. Most tires are that way. I think the MH is about 25" tall.
CAN'T WAIT FOR THE RADIAL, JOHN!!!
Old Jan 28, 2005 | 05:58 PM
DontBlink's Avatar
Default Re: 235/60/15 M&H/ET streets (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">Here you guys go,
(5.55)2 + 15 = H
11.1 + 15 = H
26.1 = H
CAN'T WAIT FOR THE RADIAL, JOHN!!! </TD></TR></TABLE>
from the tirerack website under the BFG drag radials they have it listed as this(for the mathamaticlly impared )
225/50/15= 23.9" tall
235/60/15= 26.1 tall
if the M&H's were 25" tall that would work for me, on the civic that Dturbocivic posted i dont think they look to big either,i really cant see the tire on the type R real well.
heres what im working with now, i know im gonna have to raise the car a little more since im really close as it is.
sorry for the huge pictures.
maybe im just not running the right tire pressure in them. how low can you run with M&H compared to an actual drag radial? the lowest i went with the radials was 12psi, i thought i read on BFG website not to go lower than this(12psi).
Old Feb 3, 2005 | 09:08 PM
Rob!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
the m&h tires on the itr seemed to fit really well. i liked the car alot. the tires looked comfortable in the wheel well.</TD></TR></TABLE>
paul (yellow itr) had to raise his car up quite a bit to squeeze these under there. im looking for a set of slicks myself that i can fit without raising my car much. any suggestions?
Old Feb 3, 2005 | 09:31 PM
SlicksMH's Avatar
Default Re: 235/60/15 M&H/ET streets (DontBlink)
This is the sizes of my Dot's.
(b) P235/60-14
Tread Width: 7.5"
Section Width: 9.8"
Diameter: 25.0"
Circumference: 78.4"
Rim Size: 6.5"
Compound Type: 703
(c) P235/60-15
Tread Width: 7.5"
Section Width: 9.8"
Diameter: 25.4"
Circumference: 80.0"
Rim Size: 6.5"
Compound Type: 703
John@M&H-Hashims
Old Feb 4, 2005 | 04:29 AM
VTEC-dood's Avatar
Default Re: 235/60/15 M&H/ET streets (EKsnatchback)
what is his suspension setup?
GEN2 LS
May 8, 2017 07:15 AM
90Rexx
Aug 24, 2010 04:35 PM
M15
Oct 6, 2005 07:53 PM
.RTErnie
Aug 6, 2005 08:51 AM
