running untuned???
Old Jan 27, 2005 | 07:31 PM
sickerhatch's Avatar
Default running untuned???
well i just finished my motor and i was wondering if any one had any opinions on if it would be ok to drive it with out any dyno tuning.
Heres the set up
b16a
.25 os ctr pistons
port-polish
ss valves
titianium ret.
rev valve springs
head milled.4
stock b16 cams
b-m fuel pressure reg. at 50 psi with vacume hose off
p28 with scunk 2 chip
Ive driven the car about 80 miles now and it runs good but i havnt gone over 4.5 rpm yet.And i pulled the spark plugs and there the color of cardboard witch from what i here is good. just wondering what you guys think??
Old Jan 27, 2005 | 09:59 PM
PrettyLude's Avatar
bring it to go get tuned asap, the compression is high, don't want it to blow up in your face
Old Jan 28, 2005 | 04:06 PM
Default Re: (PrettyLude)
it will get tuned as soon as i get money.just wondering if it would be ok for the motor.i cant afford it for another month or so.
Old Jan 28, 2005 | 04:22 PM
1.8turbolsvtec's Avatar
Default Re: running untuned??? (sickerhatch)
what are you going to used for tuneing
Old Jan 28, 2005 | 05:07 PM
Default Re: running untuned??? (1.8turbolsvtec)
i was going to take it to rage performance for some dyno time
Old Jan 28, 2005 | 05:18 PM
Has any one on here ever run a similar set up with no dyno tuning?What wer your results???
Old Jan 28, 2005 | 08:45 PM
MugenRacerX's Avatar
8-( lots of people do get away with doing this ,but dam if you spent so much money to build the thig why even take a chance?all you need is a wideband o2 sensor so you can be sure the A/F is safe till you get to the dyno.
Old Jan 28, 2005 | 10:44 PM
PrettyLude's Avatar
Default Re: (MugenRacerX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenRacerX &raquo;</TD></TR><TR><TD CLASS="quote">8-( lots of people do get away with doing this ,but dam if you spent so much money to build the thig why even take a chance?all you need is a wideband o2 sensor so you can be sure the A/F is safe till you get to the dyno.</TD></TR></TABLE>
Old Jan 30, 2005 | 10:00 AM
bump for more info
Old Jan 30, 2005 | 06:22 PM
Default Re: (sickerhatch)
bump
Old Jan 30, 2005 | 09:30 PM
anothersickhatch's Avatar
based on your engine mods, you are running WELL over 12:1 compression, and i guarantee your motor is detonating every time you drive it. with those pistons, your compression as around 11.6:1, and with the head milled, it would be over 12:1.
i would seriously recommend not even driving it until you have it tuned.
i had almost the same compression and my motor lasted about a week without tuning, until i destroyed two brand new pistons.
Scott A
10
Apr 25, 2014 09:01 AM
4drdohc
Dec 8, 2008 09:34 PM
Panoply
Nov 3, 2007 01:42 AM
vteczone
Dec 16, 2003 02:45 AM
hybrid901
Aug 20, 2003 06:44 AM
