code #8 civic eg
Old Jan 27, 2005 | 03:04 PM
ThisLittleSleepeR's Avatar
Default code #8 civic eg
im throwing code #8 for my 92 civic, does anyone know what might be the problem, i think code 8 is TDC. is it for Dizzy or what?
Old Jan 27, 2005 | 03:24 PM
PLAN:B's Avatar
Default Re: code #8 civic eg (ThisLittleSleepeR)
Top Dead Center Sensor (TDC Sensor). It is in the dizzy, and you can't buy it seperate. Get a new dizzy
Modified by PLANBmotorsports at 4:43 PM 1/27/2005
Old Jan 27, 2005 | 03:45 PM
PLAN:B's Avatar
Default Re: code #8 civic eg (PLANBmotorsports)
oops, I said you CAN buy it seperate at first. Sorry I meant CAN'T. Edited ^
Old Jan 30, 2005 | 09:24 AM
so i need a whole new dizzy? whould that be the reason i have a weird idle when cold, and when i just go sometimes the rpm's would fall? been like this for a long while, im finally getting irritated with it.
Old Jan 30, 2005 | 09:53 AM
TeamNextGenChris's Avatar
just replaced a distributor that had the TDC sensor break off from it's mount.car ran just as you've described.this tells the ECU where the motor is in it's rotation-it being broken can certainly lead to the distributor firing at the wrong time causing problems like you have.
before spending money on a a new distributor,troubleshoot your current one.in a a shop manual there's a procedure to test the sensor itself,and you'll also want to test the wiring to make sure there are no shorts or breaks anywhere.
Chris
Old Jan 31, 2005 | 09:36 PM
Default Re: code #8 civic eg (TeamNextGenChris)
thanks for the info
Old Feb 1, 2005 | 06:38 AM
93CivicSiSOHC's Avatar
I just had the same problem #8 code. I just replaced my LS distributor. Got a new housing for $125 (Acura-Honda) and it runs great.
sebTeggy
Oct 21, 2011 09:28 PM
crxnonvtec
Aug 20, 2009 02:40 PM
Forrest Gump 9
May 14, 2004 04:59 AM
turboxsi
Jun 10, 2003 03:32 PM
